dell e5440 turns on 3 seconds with fan at max
  • poweron
    • May 2019
    • 371
    • italy
    this card is the same as that of the other discussion E5440 VAW30 LA-9832P, connecting power turns on the power led and fan at max for 3 sec then all off, as if you didn't see the ram, then if you turn it on again with the power button it doesn't turn on, I tried to disconnect the power supply and jumper pins 5 and 6 of U1 and U2 while I re-connected the power supply, and it turned on normally, then after turning it off when it was turned back on it didn't turn back on like at the beginning
  • poweron
    • May 2019
    • 371
    • italy
    Re: dell e5440 turns on 3 seconds with fan at max
    I solved the problem, making a check of the present voltages, measuring the + 1.35V-MEN-P this was not present, measuring on PQ100 the pins 5-6-7-8 there was no voltage, on PL101 the + PWR- SRC was present on point 1 but not on point 2 of the coil, measured in ohms it was ok but it did not make contact with the pad, the welds on the coil were re-made 1.35v_B + is adorned on pins 5-6-7-8 of PQ100 and so even the + 1.35V-MEN-P is back and the notebook has started working again.
    regards
    • gitsfarmaz
      Professnal tech
      • Apr 2017
      • 30
      • Kenya
      having the same problem on the same
      • mnciks11
        • Aug 2019
        • 345
        • south Africa
        Send the schematic I want to see you solved this
          • 21874
          Schematic. https://drive.google.com/file/d/0B6I...tOR2VoV3M/view
          Bios. https://www.badcaps.net/forum/showthread.php?t=70030
          • mnciks11
            • Aug 2019
            • 345
            • south Africa
            Thank you so much bro
