HP 15-AC135NA Dead
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Re: HP 15-AC135NA Dead
    Hi, OK but I am not sure where the B + line goes? also do you think I should be able to get away with leaving that cap off? if not does anyone know its value, tolerance and voltage please.
    • brew99
      • Jan 2019
      • 132
      Use your DMM in diode mode and put the red lead on ground point somewhere, and the black lead on one side of the pad where you removed the B+ resistor. What is the Voltage reading? What about the other pad of the B+ resistor location (black lead)? What is it's voltage reading?
      If you are reading something around 0.4-0.6V you don't have a short anymore. If either are 0.00V or so, then you still have a short on the B+ line.
      If you have no short, you can probably leave the cap off, but I prefer to replace if I am going to use for long term.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        No need to apply power and test voltage at this stage. Rather you should once again test both sides of B+ resistor in diode mode. If it no more shows short, put the B+ resistor back and apply voltage going with 1v at the beginning and then slowly increasing it. I assume you have a dc supply with you.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          It will hardly matter. Just replace it with similar looking cap from a scrap board.
          • piernov
            • Jan 2016
            • 4435
            • France
            Except that if it's on B+ it'll have to be at least rated for 25V… Otherwise you'll get some nice fireworks.
            • Andyd1970
              • Feb 2013
              • 374
              • united kingdom
              #26
              Sorry for delay, I checked the B + rail both side in diode mode and got around 0.5v so replaced B + resistor and now get the red light, thank you all so much. But I want to replace the cap but have no idea on its value as there are no markings on it or near it and it is SC so cant check. Any ideas? or do you think it is OK to leave off?
              • brew99
                • Jan 2019
                • 132
                I don't think you ever mentioned the motherboard part number in the post? If you can find that, then maybe we can help you find a schematic or boardview, and look up that cap. value.
                Otherwise you might just use your DMM (if it can measure capacitance), and measure the cap right beside the one that was shorted (they look similar), to give you a rough idea for a capacitance value. As Piernov pointed out, it is most likely atleast a 25V rating as it is on the B+ line
                • Andyd1970
                  • Feb 2013
                  • 374
                  • united kingdom
                  #28
                  Hi, OK..
                  ABQ52 LA=C811P REV 1.0
                  MO: 39704880
                  SPS:815249-501
                  Date code:7J1630
                  Hope that is the correct info from motherboard
                  • Andyd1970
                    • Feb 2013
                    • 374
                    • united kingdom
                    #29
                    Hi, I have just used a PEAK Atlas ESR meter from a friend..
                    I get 165.8uf ESR 0.09 ohms.
                    Does that help ?
                    • brew99
                      • Jan 2019
                      • 132
                      I can't find that schematic or BV. Does it work now without the cap? If so, don't worry about it for now.
                      • Andyd1970
                        • Feb 2013
                        • 374
                        • united kingdom
                        #31
                        All seems to be working fine, thank you all.
                        • double_DD
                          How can I be sure that my EC chip is dead?
                          by double_DD
                          As the title suggests, how can I be sure that my EC chip is really dead?
                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                          03-12-2025, 07:47 AM
                        • Petr0x
                          Bosch 12V and 18V chargers modification
                          by Petr0x
                          Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                          You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                          Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                          05-24-2024, 01:00 PM
                        • disorder
                          ps5 edm-033 dead after hdmi/usb ports destroyed
                          by disorder
                          hello guys,
                          i need help to repair a edm-033 ps2
                          history : as always hdmi port and usb ports destroyed after unplugged
                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                          so i changed it
                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                          i don't see any projection of liquid metal on pcb.
                          01-14-2025, 12:48 PM
                        • Beton
                          Finding a dead short component
                          by Beton
                          Hi guys!
                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                          I have a bench PSU and if I try to inject voltage the voltage...
                          12-10-2021, 01:05 PM
                        • zunasthegreat
                          Chieftec GPS-450-AA with dead 20N60C3
                          by zunasthegreat
                          Hello everyone hope all doing well!
                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                          09-01-2024, 07:12 PM
