Asus Zenbook UX330UA odd power issue
  • ElJap0
    • Feb 2019
    • 10
    The power button does not turn the machine on. But when the adapter is plugged in, it will boot properly (without pusshing the power button). When in the OS, the power button responds. Can anyone shed some light on this or provide a schematic or boardview?
  • peste
    • 13588
    • ROMANIA
    Re: Asus Zenbook UX330UA odd power issue
    change the bios for the beginning
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      check voltage of bios battery if u have it
      • ElJap0
        • Feb 2019
        • 10
        I don't see a cmos, and there are a few IC's that look like they can be the BIOS. Should I just hit pin 1 on anything that looks like a BIOS chip? Also, there is no CMOS on the IO board
          • 21889
          On boards with no CMOS battery the board will power the RTC from the main laptop battery.What condition is your battery in,have you tried another battery
          • ElJap0
            • Feb 2019
            • 10
            Battery is fine. It holds a charge and charges properly when I boot into an OS. But the weird thing is that it boots automatically when the chrager is plugged in (similar to a MB Mobo externally with an 85w adapter), and once in the OS the power button functions. But if you leave the adapter out (with a fully charged battery) and try to turn it on with the power button, it does nothing
            • Retro-Hipster
              Tinkerer
              • Apr 2019
              • 125
              A question on the battery ElJap0.. When you say it is fine, how have you determined this? Have you taken a multimeter and tested the voltage of the pack? If so, have you tried testing it under load?
              There are many reason why a laptop battery can show that it has charged/is charged when it is still damaged. This could also point to a charge controller issue. If you are comfortable opening up the unit and taking the battery out, maybe stick a little 20-watt 12v bulb on across the leads of your multimeter with some crock clips and then probe the battery to see what the voltage reads. That would give a 1.7a test load and should give you an idea of what the batteries voltage is under load. (Something this maybe.)
              It is always important to understand that batteries can read the correct voltage when they have no load, but dip down below operating voltage when under load. Since this is a Lithium battery it is going to have a mosfet/under voltage protection.
              “Men always seem to think about their
              past before they die, as though they were
              frantically searching for proof that they
              truly lived.”
              – Jet (Cowboy Bebop) -
              • ElJap0
                • Feb 2019
                • 10
                Could you clarify how this would help to troubleshoot (no sarcasm intended). The power button not triggering the P.O.S.T. with a charged battery would lead me to think something is wrong with an S5 rail. That maybe the keyboard (or something else) is not being supplied power. Your input is appreciated, but could you clarify your thoughts on why a bad battery would be the culprit (again, no sarcasm intended)
                • Retro-Hipster
                  Tinkerer
                  • Apr 2019
                  • 125
                  Oh, no problem. This was me going off of what SMD flea was mentioning about laptops that do not have CMOS batteries. The idea behind this would be that the battery that is showing as fully charged main fact just be reaching its Target voltage quickly due to damage but then quickly dropping below its cutoff voltage. At that point the mosfets would not be providing any power to the laptop and you would not be getting any power. I guess the real take away from what I was saying was just that people often test batteries just by checking the voltage without a load only to find later that the battery cuts off immediately when a load is applied.
                  truly lived.”
                  • ElJap0
                    • Feb 2019
                    • 10
                    How do I test a laptop battery? And could the battery still be the culprit if the laptop stays on without the adapter, after being powered on by connecting it (without hitting the power button)?
                    Last edited by ElJap0; 05-25-2019, 03:47 PM. Reason: wanted to adendum without creating another "reply"
                    • ElJap0
                      • Feb 2019
                      • 10
                      Also, you're saying it might be a mosfet that is looking for a signal from the battery before letting the signal from the power button come through (or something of the sort (a "p" or "n" mosfet that relies on the battery signal))?
                      • Weelcup
                        TopTech
                        • Oct 2017
                        • 307
                        Hi.
                        I had a quick look on this post. Can you check the voltages of the battery pins while it is connected to the board. To see they provide any voltage to the board. Cuz I would suspect the battery to begin with.
                        • Troos
                          • Mar 2020
                          I'm having the same exact odd power symptoms. Was there any resolution to the issue? I checked and my battery seems ok - it is fully charged (12V) and maintains that voltage when plugged into the mother board. I'm checking to see if there is an updated BIOS to download.
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • bajdik
                            Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                            by bajdik
                            I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                            Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                            I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                            Unfortunately, I don’t have access to the schematic.
                            It seems to me that when I bend the board, something changes.
                            Could this...
                            08-13-2025, 07:26 AM
                          • garretofriviaaaaa
                            Asus TUF Dash FX516PM Power Issue
                            by garretofriviaaaaa
                            Hello, I've had a problem with this laptop for a while. I've replaced the motherboard after it died, and it was seemingly working fine after, but it stopped powering on after I shut it down. if I remove the battery connector and plug it back in, it will boot fine, but if I shut it down again it will not power up after that until I unplug and replug the battery in. When I press the power button the caps lock light will light for half a second but will not boot. I've tried replacing the RAM and the battery but still the same issue. The only thing I've found to get it to turn on consistently was...
                            08-29-2025, 05:47 PM
                          • MakNCheese
                            ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                            by MakNCheese
                            I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                            Symptoms:
                            • Severe lag across the system, including BIOS navigation.
                            • Slow boot times and unresponsive performance in Windows.
                            • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                            • No error messages or BSODs, just extreme sluggishness.
                            What I've Tried:
                            • Replaced
                            06-04-2025, 12:48 AM
                          • mkdj
                            by mkdj
                            Mark and model: ASUS X571
                            Tests already made:
                            - I have removed...
                            07-14-2025, 09:16 AM
