MSI MS-16JB1 no VCC_GT voltage
  • nicolae788
    • May 2015
    • 31
    I have a MSI MS-16JB1 board that has all the power sequence except VCC_GT. Impedance on VCC_GT it's 1.7 Ohm, i have PWM from the ISL going to the smart FET's that control VCC_GT, FCCM_B it's kept low as opposed to the FCCM_A for the VCC_core smart FET's that it's high. NO shorts and no other anomalies except no BL_ON because no EDP_BKLTEN that comes from PCH and goes to an AND gate ( NC7S08 ). The AND gate receives the other signals. This EDP_BKLTEN could be because no VCC_GT i presume, but no VCC_GT because of EDP_BKLTEN, i doubt. Also no display on HDMI or laptop screen. I also checkd with a flashlight if there is something displayed but nothing. Discrete Nvidia GPU has power 0.8v and all the rest of the peripherals. If i plug a usb keyboard no CapsLock or NumLock lights but 5V present at USB ports.
    The board starts and stays on, fan spin after 10 seconds when the CPU gets warm. BIOS reprogrammed and looks fine.
    I do not have a schematic for this one and i am using as a reference the MS-16J51 one.
    If anybody has some ideas they would be greatly appreciated.
    Thank you!
  • peste
    • 13588
    • ROMANIA
    Re: MSI MS-16JB1 no VCC_GT voltage
    https://www.badcaps.net/forum/showthread.php?t=70908
    can help you that
    • nicolae788
      • May 2015
      • 31
      Hey, thanks. I remember i did a search but nothing on ms-16. Thank you very much. I will study that thread
      • piernov
        • Jan 2016
        • 4439
        • France
        Board not POSTing apparently. What's the exact voltage you get on CPU VCore? Check PLTRST# if you can find it.
        Make sure you use known good and compatible RAM.
        • nicolae788
          • May 2015
          • 31
          Hi, Vcore 1.07. I am not in the lab now, but that's what i remember. I did not checked plt_rst as long as i have nvidia power, but will check it. I know were it is. Also same feeling here, bad ram. Will take a look again at bios and check the existence of the boot block.
          Thank you
          • nicolae788
            • May 2015
            • 31
            Back to this board. I wanted to forget it, but i can't . Rechecked all voltages and signals. all it's there apparently, but one thing caught my attention. Pin 1 on BIOS chip ( CS, chip select ) instead of going low as stated in the datasheet it stays high. CS should be driven low by the EC chip on pin 128. I replaced the EC chip from a similar board and no change, still stays high. Any suggestions here? Indeed not posting....
            Thanks.
            • piernov
              • Jan 2016
              • 4439
              • France
              CS# will go low only when the BIOS chip is being read. Checking this signal with the oscilloscope is a good way to know if the BIOS is being read. If you have a fast multimeter, you may see it flicker lower than 3.3V when turning on.
              CS# should be driven by the PCH, as it becomes the master of the SPI bus when it's turning on.
              EC may be the master of the same SPI bus if its firmware is inside the BIOS chip, so it has to read it while initiating the power sequence, but once it has finished its job (after getting in an S0 state for example) it should not be driving CS# anymore.
              • nicolae788
                • May 2015
                • 31
                @piernov sorry for the delay in replying. ok, that makes sense. For the moment i am setting this board aside. Can't find the culprit. If i ever get to the bottom of this will post here my findings. Thank you.
                • Fernon@Repair
                  Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                  by Fernon@Repair
                  i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                  VCCIO voltage ok
                  VCCSA Voltage OK
                  VCCPLL Voltage OK
                  Ram Voltage ok
                  RamVTT OK
                  VPP 2.5 OK
                  But No Core Voltage
                  and i want to this vrm ic datasheet or pinout (ISL69269)
                  anyone have this ic pinout voltages?...
                  06-25-2025, 07:19 AM
                • electron_jj
                  Panasonic TH-L42D25A checking the PSU output voltage
                  by electron_jj
                  Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                  I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                  08-29-2021, 08:13 AM
                  Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                  I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                  The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                  Now...
                  06-09-2024, 10:57 AM
                  ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                  3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                  Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                  core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                  configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                  serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                  Based on Intersil's Robust Ripple Regulator...
                  11-05-2024, 03:24 PM
                • ruletero
                  Acer a515-43 low battery charge voltage
                  by ruletero
                  Hi
                  Acer A515-43
                  LA-H801P
                  Fail: Does not charge battery, has low voltaje on connector.
                  Laptop didn't want to turn on, only charge led blinked.
                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                  10-24-2022, 02:31 PM
