No backlight. How to check Inverter card
  • IamPritesh
    • Aug 2017
    • 356
    • India
    I have this compaq preasario v3000 . It now starts fine..I can see picture if I use flashlight.. and on external monitor .
    I suspect it could be a case of either bad invertor or ccfl. How do I check this ? I do not have any spare invertor to swap and test....
    p.S -- Togling the lid switch enables backlight for a second and then it goes back to black screen
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: No backlight. How to check Inverter card
    what about checking backlight enable signal?
    • IamPritesh
      • Aug 2017
      • 356
      • India
      where could I find this signal ? LVDS connector ? I dont have the schematics
      • mmartell
        • Oct 2013
        • 3189
        Pictures, pictures, pictures where are the pictures ?
        • piernov
          • Jan 2016
          • 4439
          • France
          Usually bad CCFL. Connect any other laptop CCFL to confirm. (connect backlight connector from another laptop panel)
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            https://cdn.badcaps-static.com/pdfs/...4c839989cb.pdf
            check BRIGHTNESS_CONN
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
            • lostone
              Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
              by lostone
              Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
              First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
              When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
              05-19-2024, 11:40 AM
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
            • Comp_Pro
              No Backlight Macbook A1990 820-01041
              by Comp_Pro
              Hello all,
              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
              Tests performed:
              There is no backlight even with a good screen.
              Backlight IC is receiving the correct support voltages.
              Fuse F8400 ok
              Current sense resistor R8400 ok
              Backlight IC is receiving 3.3V on enable pin.
              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
              Backlight IC receiving 5V from PP5V_G3S
              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
              05-06-2024, 10:23 PM
            • jimbofz
              lg 32LC46 backlight inverter board fault
              by jimbofz
              Hi this oldie had no backlight .after replacing caps on 24v rail ,
              still no b/l this uses inverter type:1315 B1-16A,
              im sure ive come across the same inverter in a samsung possibly le32r88bd ?
              all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
              this allows protect to be temporary overridden.
              b/l now comes on
              but the left hand side of pic is gradually darker than the right side
              i have the cct for the tv
              but it does not have inverter cct.
              i opened it up to inspect the ccfl tubes
              and they dont have any...
              12-19-2021, 06:58 AM
