HP 15Z shorted QFN with weird ID
  • TVMexicana
    • Mar 2019
    • 32
    Hello all,
    I am continuing to trouble shoot motherboards. This time around I have found a bad QFN chip responsible for one of the power rails in this HP 15z-cd000. It is a DC-DC converter circuit. Dead short to ground through this IC. I'd like to replace it but the number on it is probably propiertary, it is marked something like AWV70H or possibly AWV709, or AWV7DH. I can't exactly tel but googling does not give me any results. I'd really love to be able to replace it as I think it's the only issue with this MB. I'm gonna try to dig through some junkboards and see if I can find it there too.
  • R_J
    • Jun 2012
    • 9607
    Re: HP 15Z shorted QFN with weird ID
    Any pictures of it? attach them to your post It might be a TPS79918DRV
      • 21922
      It could be a Silergy SY8286BRAC
      • R_J
        • Jun 2012
        • 9607
        I agree, it is more likely the Silergy SY8286BRAC (AWV QFN20_3X3) The last 3 letters are usually date/mfg codes
        • TVMexicana
          • Mar 2019
          • 32
          thanks guys, i lost track of this project but it seems it is indeed this SY8286BRAC, online pictures show something that looks identical except for last 3 digits. Are there known more common replacements for this IC?
          • brew99
            • Jan 2019
            • 132
            They are on Aliexpress..
            https://www.aliexpress.com/item/3286...AbTest=ae803_3
            • pc_okay
              G703GXR Dead CPU? shorted CPU power mofset replace, missing DRAMRST#
              by pc_okay
              Hello friends,
              I replace a shorted mofset (PU8104), now laptop is starting but no display, stopping at DRAMRST#.
              Resistance to ground on PL8104 is around 1-2 ohm, quite low but voltage seems ok 0.995V
              Any help would be appreciated it's a nice laptop !
              Thanks. 😃
              04-02-2025, 04:48 AM
            • reessi
              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
              by reessi
              Hello:
              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
              I started on the ACER:
              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
              10-29-2024, 11:31 AM
            • Yanleb
              Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
              by Yanleb
              Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
              I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
              D608, good
              D618 RF101L4S, good (See warning 1 below)
              D619 RF101L4S, good (See warning 1 below)
              D865 RF101L4S, shorted (See warning 1 below)
              IC464 Inverter HA MC74HC1G14, shorted...
              03-09-2020, 12:00 AM
            • Shuasmith14
              330S-15IKB Components to replace along with shorted power MOSFET
              by Shuasmith14
              Hello. I'm currently working on a Lenovo Ideapad 330S-15IKB that has no power, no power light, dead. I found the schematics and I'm seeing proper voltage at the drain of the first DC IN MOSFET and nothing after. After doing some research and finding the power supply troubleshooting guide in this forum. I tested the second DC IN MOSFET and it's shorted from drain to source. My main question is since I'm new to doing this, I thought I heard somewhere that any time a MOSFET goes, you're supposed to replace the controller as well. That may not be right but I want to check if there's anything else...
              08-22-2021, 06:16 AM
            • modtool
              HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
              by modtool
              Hi to all,
              the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
              I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
              I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
              04-01-2025, 08:22 AM
