Asus Gaming FX553V No power
  • eng.jaudat
    • Aug 2016
    • 63
    • Palestine
    Hello, i'm trying to fix Asus Board
    Model of the Laptop is: FX553V
    MB: (GL553VD Rev:2.0)
    when i check the mosfets power i found the second one is dead.
    after i changed it the mobo still not working.
    the first power mosfet not pass the 19V, and there is no voltage on the gate.
    how i can know the reason of loss the voltage in the first and second mosfets gate?
    i'm searching for the schismatic but can't found it any where on the web
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: Asus Gaming FX553V No power
    check charging ic pins for voltage and compare it to datasheet
    • leone0310
      • Jun 2013
      Check for shorted cap after the second fet.
      • eng.jaudat
        • Aug 2016
        • 63
        • Palestine
        thanx pro,
        i can't found any data sheet for this mobo online.
        BQ735 is the charging ic?
        • eng.jaudat
          • Aug 2016
          • 63
          • Palestine
          i'm trying that using my power supply, there is no rise on the amps. so i guess there is no shorted cap.
          but i will be sure using my multimeter again
          • eng.jaudat
            • Aug 2016
            • 63
            • Palestine
            BQ735 is the charging IC, by reading the data sheet of it i must read 19V come directly from the DC jack to that ic. i can read just 2.45V.
            is that normal?
            please excuse my rare knowledge. i'm still beginner.
              • 21978
              Boardview at post# 3 https://www.badcaps.net/forum/showth...hlight=GL553VD
              Change the first mosfet as well.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3628
                • slovakia
                NEVER DO IT!!!
                if u have shorted some of high side fet u will kill CHIP or whole mb
                • eng.jaudat
                  • Aug 2016
                  • 63
                  • Palestine
                  REALLY!!
                  i just do it on the first and second mosfets. to know if there is a cap shorted in the mobo.
                  honestly its a very useful way, and helping me in so many dead mobo.
                  • eng.jaudat
                    • Aug 2016
                    • 63
                    • Palestine
                    thank you so much, i will read it so carefully.
                    and i will try to change the first mosfet. but you don't thing that my problem in BQ735?? as there is no voltage in the gate of the first mosfet?
                      • 21978
                      Probably is BQ735, its always better to change the two mosfets together,even if one is tested working.
                      • eng.jaudat
                        • Aug 2016
                        • 63
                        • Palestine
                        can i use BQ737 instead of BQ735??
                        • on/off
                          • Oct 2016
                          • 333
                          • Indonesia
                          No.
                          Both IC have different pin out
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Most likely some fet or cap is shorted. Did you checked resistance to gnd on B+ line. there should be a resistor just after 2 dc in fets and on that you can check resistance to gnd. You can remove that resistor and then apply power and see if 19v reaches on those pins of fets where you were not getting any voltages.
