Fujitsu nh532 wont start unless cmos battery removed
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Hi any help is appreciated. I have tried a few different bios files. The power buttons works fine. Only if bios battery is removed it will boot up and can be switched off with power button but will not switch on again via button.
    I cannot find a schematic or boardview.
    on KBC
    ac_present is 0v
    Pm_pwrbtn 3v
    PM_RSMRST 3v
    ec_rst 3v
    ac_in_oc 3v
    vsuson 3v
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: Fujitsu nh532 wint start unless cmos battery removed
    is battery ok? voltage more than 2.5V
    • Bisketti
      • Oct 2013
      • 252
      • Ireland
      yeah tried with new battery same. Im trying to find out why ac_present is 0v from kbc with or without cmos battery.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3610
        • slovakia
        i think ac_present is driven by ACOK from ic like BQ
        • Bisketti
          • Oct 2013
          • 252
          • Ireland
          Thanks for your help but had to return unit to customer.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
          • magistertc
            CMOS battery drains quickly
            by magistertc
            This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
            as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
            Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
            Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
            configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
            07-06-2024, 09:55 AM
          • rumpumpel1
            ThinkPad T470 does not power up with CMOS battery attached
            by rumpumpel1
            I have a ThinkPad T470 that will not boot when the CMOS battery is plugged in.
            With only the fan, a RAM module and a USB-C monitor attached, but no CMOS battery, it starts up normally, i.e. after about 90 seconds and two reboots, it stops with a message to press F1 to enter date & time.
            If the power is switched off and a CMOS battery is inserted, it restarts as described above. However, after switching it off and on again, it does not turn on. It draws almost no current and shows no sign of life.
            I used a different CMOS battery and checked the components around the battery...
            04-27-2023, 10:46 AM
