Wiped critical info from bios HELP!!
  • Sumlameusername
    • Mar 2019
    • new zealand
    O.k here's what happened...
    Knowing that Microsoft will no longer be supporting windows 7 next year I wanted to duel boot my laptop running win10 & Linux mint.
    I installed win10 but wasn't happy with the install so went ahead for a reinstall, somewhere along the way I accidentally wiped a partion which must have held BIOS info like s/n, p/n, uuid, etc.
    Now when I boot it tells me it's in a non commited state, I tried to rebuild the partition via cmd & no luck, I realise that it needs rebranding & I have HP DMI software But to make matters worse there is no physical info on the laptop such as serial no, model no etc.
    I'm at a dead end and dont want to make matters worse by attempting things that are going to dig my hole deeper so have turned to the forums, I consider myself a basic user this is my first ever post and Im out of my depth.
    The install was a UEFI Win10 on GPT formatted partition from usb.
    My laptop is an old but stable HP Elitebook 8540p.
    i5
    2.53GHz
    8 GB ram
    BIOS Revision 68CVD Ver. F.60
    Thanks in advance for any help.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Wiped critical info from bios HELP!!
    The BIOS shouldn't be on the hard drive! We're not talking about 1980s or some 1990s systems, where you can't get into the BIOS without a drive, by hitting a key.
    Reminds me of an old system I had on two different occasions, where to access the BIOS, you had to have a floppy disk, (or a hard drive) because that's where the setup utility was, if not also written to certain hard disk drive sectors.
    Even on newfangled BIOS systems, (a.k.a. UEFI) you are usually only going to end up in shit creek, when you can't disable "Secure Boot".
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Sounds like you nuked the bootloader.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • diif
        • Feb 2014
        • 6978
        • England
        Is secure boot enabled or disabled ?
          • 31255
          UEFI stores some shit on a hidden partition, but it's not critical - wipe the drive clean and go into the bios and check it's settings.
            • 21932
            "there is no physical info on the laptop such as serial no, model no etc."
            It should be on a sticker on the base or inside the battery compartment.
            • pirati
              by pirati
              10-27-2025, 04:20 PM
              by Vesko356
              08-11-2023, 03:27 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • Bloodhoundje
              by Bloodhoundje
              03-16-2024, 03:12 PM
