MOSFET alternative FDMC6679AZ
  • kalemaroni
    • Jun 2016
    • 171
    Is there a MOSFET that is close enough to FDMC6679AZ that I could use as a substitute? The customer isn't giving me enough time to order this part from China.
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    Re: MOSFET alternative FDMC6679AZ
    si7129dn
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3567
      • slovakia
      dont bother finding the right alternative. grab any p-channel mosfet from any bboard that have more than 20A max current
      • diif
        • Feb 2014
        • 6978
        • England
        RS has them in stock. https://uk.rs-online.com/web/p/mosfets/7599522/
        • kalemaroni
          • Jun 2016
          • 171
          Does it matter if the number of pins is different?
          • kalemaroni
            • Jun 2016
            • 171
            Originally posted by diif
            Gosh, thanks! Don't know how I missed that, how annoying.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3567
              • slovakia
              did u see usual mosfet with different pinout than 1/3/4?
              • kalemaroni
                • Jun 2016
                • 171
                https://cdn.badcaps-static.com/pdfs/...11df91fa10.pdf
                https://cdn.badcaps-static.com/pdfs/...7590497db8.pdf
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3567
                  • slovakia
                  first is different package and second is usual 1.3.4
                  • Jane
                    How do you test MOSFET in laptops ?
                    by Jane
                    I tried to use this method:
                    Testing an N-channel MOSFET:
                    Step 1: Discharge the Gate (turn off the MOSFET)
                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                    Step 2: Charge the Gate (turn on the MOSFET)
                    Now, place the red probe on the Gate (G) and the black probe on the
                    09-27-2024, 03:31 AM
                  • Nooy
                    VGA MOSfet permanently shorted and loss of MOSfet pad
                    by Nooy
                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                    02-14-2024, 02:26 AM
                  • edugimeno
                    Find substitute for mosfet in servo board of versacamm sp-540v plotter
                    by edugimeno
                    Hi There!
                    I am currently serviciing a plotter versacamm sp-540v
                    I found a shorted mosfet labeled J553 which corresponds with SJ-553s (surface mount)
                    Neither local stores nor other webpages that are able to provide it before 1 month (only aliexpress, with 1 month delivery) can provide this part
                    I need to find a substitute for it. Can anyone give me a hint on a part that I can use to replace it?
                    Also, given the schematic Im attaching (pg 36, transsitor Q1) , does it make sense that the whole machine won't turn on when I press the POWER button on the panel? This...
                    10-27-2022, 10:46 AM
                  • AppleLover123
                    Asus X712EA 3 volts after the first mosfet
                    by AppleLover123
                    Hey guys,
                    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                    Now i thought something...
                    12-15-2024, 07:49 AM
                  • MicroSMD Lab
                    ASUS ROG Zephyrus GPU Mosfet repeat failure
                    by MicroSMD Lab
                    The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                    01-10-2024, 06:36 AM
