Clevo N150SD powers on for 10 secs
    • 20758
    Re: Clevo N150SD powers on for 10 secs
    The ME,or Management Engine is a part of the bios that often gets corrupt. Your bios is split across 2 chips,sometimes the bios is just on 1. The clevo bios you downloaded has 2 bios files,1 is the 4MB bios the other is the full size 6MB bios.That 6MB bios has to be split into 2 seperate files using a hex editor to get the 2MB bios. Your bios backup has the new 4MB bios so just flash the attatched 2MB bios and verify its flashed ok. If it boots its fixed ,if not its back to testing .
    • Johndill
      • Aug 2015
      • 314
      I flashed your U18 NEW to U18 with no difference.
      For U17 I opened N150SD.01 from the downloaded bios and flashed it to U17, is that correct? If not, could you send me the correct bin file for U17?
        • 20758
        N150SD.01 is the right one for 17 .As you`ve flashed a good bios now to U17 and U18 you can rule out the bios being a problem,the other members will tell you what to test next .
        • Johndill
          • Aug 2015
          • 314
          After opening N150SD.01 in the program it would show this message, after clicking ok it showed up in the hex side looking the same as my dump, is that all good?
            • 20758
            I opened N150SD.01 with my CH341A software and got the same message,closed the software opened again and the error message was gone. If you read the bios and compare it with the file N150SD.01 they should both be exactly the same,just to double check that verifying after programming worked. Use a hex editor to compare the 2 files or a hashing tool,such as hashcalc (ok on win 7) https://www.slavasoft.com/hashcalc/
            • Johndill
              • Aug 2015
              • 314
              Ok great, it should be all good, thank you. :-)
              • Johndill
                • Aug 2015
                • 314
                Stated in the first post CPU Vcore is 1.69V, PL1 & PL2 coils, isn't 1.69V rather high for Vcore?
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  #28
                  1.7V on VCore is perfectly fine for Haswell.
                  • Johndill
                    • Aug 2015
                    • 314
                    Ah good :-)
                    Where do you think I should start next?
                    • Techtiger
                      • Oct 2014
                      • 1601
                      • france
                      #30
                      check PL8 1.5VS
                      all pins of U10 excepte 15 & 11
                      check PQ35/36 D1 D1 for 19V in
                      PU4 pin 21 3 9
                      PU6 2 16 15 9
                      • Johndill
                        • Aug 2015
                        • 314
                        Originally posted by techtiger
                        check PL8 1.5VS
                        PU4 pin 21 3 9
                        PU6 2 16 15 9
                        PL8 - 1.49V
                        U10
                        pin1 - 3.28V
                        pin2 - 3.28V
                        pin3 - 1.7mV EN1 missing
                        pin4 - 3.28V
                        pin5 - 0.0mV EN2 missing
                        pin6 - 3.28V
                        pin7 - 3.28V
                        pin8 - 0.0mV
                        pin9 - 0.0mV
                        pin10 - 0.3mV
                        pin12 - 0.3mV
                        pin13 - 0.3mV
                        pin14 - 0.3mV
                        PQ35
                        pin1 - 18.6V
                        pin2 - 18.6V
                        PQ36
                        pin1 - 18.6V
                        pin2 - 18.6V
                        PU4
                        pin21 - 5.2V
                        pin3 - 0.2mV EN missing
                        pin9 - 3.36V
                        PU6
                        pin2 - 5.2V
                        pin16 - 0.54V
                        pin15 - 0.2mV
                        pin9 - 5.2V
                        • Techtiger
                          • Oct 2014
                          • 1601
                          • france
                          #32
                          Originally posted by Johndill
                          PL8 - 1.49V
                          U10
                          pin1 - 3.28V
                          pin2 - 3.28V
                          pin4 - 3.28V
                          pin6 - 3.28V
                          pin7 - 3.28V
                          pin8 - 0.0mV
                          pin9 - 0.0mV
                          pin10 - 0.3mV
                          pin12 - 0.3mV
                          pin13 - 0.3mV
                          pin14 - 0.3mV
                          PQ35
                          pin1 - 18.6V
                          pin2 - 18.6V
                          PQ36
                          pin1 - 18.6V
                          pin2 - 18.6V
                          PU4
                          pin21 - 5.2V
                          pin9 - 3.36V
                          PU6
                          pin2 - 5.2V
                          pin16 - 0.54V
                          pin15 - 0.2mV
                          pin9 - 5.2V
                          For U10
                          pin 3 dGPU PWR EN pull up from R157
                          pin 5 3V3 MAIN EN come from U7 BGA
                          PU4 pin 3 EN missing that why PL9 PL10 no out put
                          test PQ9 gate ?
                          may be it's BIOS or BAD BGA some one else can help ?
                          • piernov
                            • Jan 2016
                            • 4435
                            • France
                            #33
                            I'm not sure where we are at.
                            Does it have PLTRST#?
                            Was a known good BIOS tried?
                            Does it have activity on BIOS CS# pin?
                            Does it seem to POST?
                            • Johndill
                              • Aug 2015
                              • 314
                              For U10
                              test PQ9 gate ?
                              Pictures attached.
                              PQ9
                              B 1.7mV
                              C 3.2V
                              E 0.3mV
                              B to ground 0.736Kohm
                              Bios flashing attempt from post#15 to post#25.
                              PLT_RST# U25 pin16 3.2V
                              U17 CS# pin1? 3.2V
                              Here is a video of what it does: https://youtu.be/BGkaSCkJktk
                              Power LED goes from orange to white
                              CPU on the left, no fan spin
                              GPU on the right, short fan spin (heatsink currently off, stays cold)
                              Stays on for roughly 15 seconds before turning off, orange light.
                              There is no video out on display.
                              • Johndill
                                • Aug 2015
                                • 314
                                What should I do next?
                                • Techtiger
                                  • Oct 2014
                                  • 1601
                                  • france
                                  #36
                                  Guys what will happen if he remove Q9 R157 bypass dGPU PWR EN to R158 to Enable to output 3.3V AON at page 73 3.3V AON become 3V3_main_EN with a 10K Resister ???
                                  • Johndill
                                    • Aug 2015
                                    • 314
                                    Bump
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      You mean the input or similar? Because the last Intel processor rated at 1.7V Vcore, was a Pentium III, LOL.
                                      Looks like the processor will get damaged.
                                      ASRock B550 PG Velocita
                                      Ryzen 9 "Vermeer" 5900X
                                      Arc A770 16 GB
                                      eVGA Supernova G3 750W
                                      Alienware AW3423DWF OLED
                                      • Johndill
                                        • Aug 2015
                                        • 314
                                        Bump.
                                        • piernov
                                          • Jan 2016
                                          • 4435
                                          • France
                                          #40
                                          You are using a known good DDR3L RAM stick right?
                                          If it still has VCore but is not POSTing, you can probe BIOS CS# pin with the oscilloscope and LPC bus too (on LFRAME#) to see if there's any activity but it won't help much anyway. It can be almost anything, EC, PCH, CPU, maybe GPU, random stuff going on somewhere…
                                          I'd try another known good BIOS.
                                          • Chivo77
                                            DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                                            by Chivo77
                                            hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                                            1- After receiving power SIO_SLP_S0# goes high and never changes.
                                            2-every...
                                            07-03-2025, 09:20 AM
                                          • dicky96
                                            RTX 3080 Ventus 10GB OC - powers on for 10 secs then off again
                                            by dicky96
                                            Hey guys has anyone come across this fault?
                                            MSI RTX 3080 Ventus 16GB OC
                                            The GPU powers up, all voltages look OK, Vcore 0.76V, Vmem 1.38V, PEX 0.95V
                                            Then after about 10 secs or so all voltages power back down again apart from 5V and 1.8V.
                                            It does not seem to be temperature related - if I power off and on immediately, it just does the same thing again
                                            I have a power sequence chart that says another voltage powers up after 1.8V and before PEX . It could be MSVDD but I am not totally sure
                                            Does anyone have a schematic...
                                            01-28-2022, 11:55 AM
                                          • narf
                                            Epson EB-U42 projector / Caps with 0.7 ohms ?!
                                            by narf
                                            hi all,
                                            first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                                            i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                                            what i've found so far:
                                            - the PSU does its job and supplies 12V to the mainboard via the connector.
                                            - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                                            - not far away, there's the first cap with a resistance of 0.7 ohms....
                                            07-02-2024, 03:53 PM
                                          • Günter Schuch
                                            searching for Schematics & Boardview for Clevo P641HK1
                                            by Günter Schuch
                                            hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                                            Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                                            05-14-2025, 06:34 AM
                                          • peterwang
                                            CLEVO PCB:6-71-V2500-D02
                                            by peterwang
                                            Hi! I encountered a Clevo brand laptop that needed its boot LOGO modified. I found the LOGO address, but after the modification, the machine stopped displaying it. I'm puzzled. It worked normally before the 11th generation of CPUs, but it stopped working from the 12th generation onwards! The LOGO addresses are:
                                            166BACEC-6793-4F38-213F-DE0BEF4FEF95
                                            166BACEC-6793-4F38-213F-DE0BEF4FEF97
                                            166BACEC-6793-4F38-213F-DE0BEF4FEF99
                                            I have provided the BIOS and LOGO files that require LOGO modification, and I hope someone can help me.
                                            post moved...next time look for a thread...
                                            07-05-2025, 03:57 AM
