iphone 5s all working except audio in bt
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    iphone 5s all working except call in bt, music in bt is playng fine
    i hear the call in earpiece and in speaker but no via bt ... any suggest?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3573
    • slovakia
    Re: iphone 5s all working except audio in bt
    as BT works fine with music, dont think it is hw fault. did u try to flash software?
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      already flashed in dfu
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
      • k24a1
        JVC I'Art AV-27F703 Left speaker audio not working
        by k24a1
        Hello Badcaps.net!
        I have an old-school CRT TV that's a JVC I'Art 27F703 from july of 2002 that I use for my older game systems. It has been working great until I noticed that the left speaker is not working. I have also tried adjusting balance and trying external speakers, and that even had the same issue though the equipment itself passed the sound test! I actually took a closer look inside and some of the capacitors on the audio circuitry portion of the mainboard were starting to leak underneath! They were samsung capacitors and uh, I don't see those ever being touted as reputable.......
        06-21-2023, 09:38 PM
      • FZG
        EVGA Nu Audio Sound Card - Not Working
        by FZG
        I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
        The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
        I found...
        03-07-2025, 11:44 AM
      • Wachenaggo
        iPhone 6s Plus Ghosting Image intermittent LCD Screen not working.
        by Wachenaggo
        i got this iPhone 6s Plus Ghosting/Doubling Image intermittent LCD Screen not working and Touch Not working
        i check CHESTNUT Voltages its there or does anybody know what is this issue....
        05-08-2023, 08:11 AM
      • Featurea
        Macbook air a1932 not working with audio board connected
        by Featurea
        I have macbook air a1932 2018 and it has water damage. Audio connector on motherboard was burned on PPBUS_G3H signal. Without this audio board laptop is working perfectly fine, but of course without sound and touch ID. I changed burned connector, flex cable and audio board. But connecting this all, Mac is not starting, nothing on thermal camera... Do you know what other can be damaged on this signal what can cause this behaviour? Nothing on motherboard looks burned...
        05-25-2022, 07:59 AM
