Lenovo S41 - ALW power keeps like restarting
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Hello.
    Have this lenovo that customer sais was sutted down during diagnostic app and start without video. but when it gets to me it looks like IC for ALW power is keep restarting. The ALW 3,3 and 5V rail goes up for a half a second and again after few seconds. Dont have schematic as i see it is not awailable
    when it not give ALW it board consume 0.49W and when ALW works it consume 0.13W which is normal consume
    i found that i have enable signal for just half of second. vreg voltages is ok and steady
    after few klicks on "novo" button board start for two seconds and ALW miracle stays on for about ten second and than does down again
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: Lenovo S41 - ALW power keeps like restarting
    i flashed bios and now it works just oposite way.
    ALW stays as it shoud be but after power button or "novo"button, it draws 0,50W and after few seconds ot goes off
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      how to goe further with this guys?
      have anybody boardview or something for that board that will help?
      this board is also for Yoga 500
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        what is the mainboard ID and revision?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3628
          • slovakia
          Lt41 mb
          14217-1m
          448.03n03.001m
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            I searched the net and it seems the schematics is not available freely. only a pay-site shows a Block diagram of this laptop.
            I hope someone has it and uploads it here.
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              Going further without schematics takes a lot of time and work. It usually leads to an incomplete repair.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3628
                • slovakia
                boardview will be enough but even it is not available
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • Mita99
                  Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                  by Mita99
                  Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                  Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                  Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                  04-27-2025, 07:20 PM
                • Dr.d
                  Help please..Lenovo ideapad 5 14itl05 power and charging problem
                  by Dr.d
                  I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                  Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                  04-05-2024, 11:48 AM
