Dell Inspiron 5559 No Display
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Hello, I have above said model.
    Please help me, It turns on without no display. Every voltage supply is ok. Tried different BIOS and original clean me bios but no effect.
    Problem is it looks like display about to come, fan spins high. When I power on display goes dark without any data and backlight.
    Any help will be appreciated. Thanks.
    Original bios attached.
    • 20844
    Re: Dell Inspiron 5559 No Display
    Did you test on external monitor .
    • dspok
      • Jan 2014
      • 553
      • Nepal
      yes, with no luck.
        • 20844
        What is your service tag number .
        • Techtiger
          • Oct 2014
          • 1602
          • france
          did you check DIMM SLOT
          +0.675V DDR
          +DDR VREF VTT
          +1.35V MEM
          DDR DRAMRST
          +5VS +3VS ON U22 OK ?
          All voltages in U5602 are ok ?
          All voltages in U15 are ok ?
          • dspok
            • Jan 2014
            • 553
            • Nepal
            Its G7DDL72, I hope you can do latest bios update from dell.
            +0.675V DDR
            +DDR VREF VTT
            +1.35V MEM
            DDR DRAMRST
            All voltages you specified are ok.
            • dspok
              • Jan 2014
              • 553
              • Nepal
              I have same issue with another model HP 640 G1.
              https://www.badcaps.net/forum/showthread.php?t=75074
              Problem on both system is same fan spins fast and no display.
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Do you have the oscilloscope to test Bios data
                • on/off
                  • Oct 2016
                  • 333
                  • Indonesia
                  Try this from official:
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    I have the same problem here
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Fan goes high when vcore is not present on many dell/sony.
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • The WABBIT
                        Dell Inspiron 5559 need BIOS Master PW
                        by The WABBIT
                        I had recently purchased a used Dell Inspiron 5559 that I had found at a local pawn shop. And of course the system is locked. And I have no idea what the Admin pw is and I have no information for the previous owner.
                        After many days of research I have found that this system, like many new system, require a Master PW/Code to unlock it or reprogramming of the BIOS.
                        Contacting Dell Support was a waste of time. They won't give me the the Master PW/Code unless I have the information of the Registered owner that they have on file. They even gave me a link to a page on their...
                        07-12-2021, 04:20 PM
                      • zlr8r
                        looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                        by zlr8r
                        looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                        cheers
                        Dell Inspiron 17 (7786) Laptop
                        Service Tag: 5J0NHT2
                        Bios: 1.9.0
                        MOBO: RO 15 17 WHL 2GB MB / 18706-2
                        Attached;
                        1. My saved bios using a programmer
                        2. Dells Bios updater .exe (v1.16)
                        3. Dells Bios recovery file
                        4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                        5. Image of ME...
                        12-18-2023, 03:08 PM
                      • mikeybass
                        by mikeybass
                        04-23-2025, 04:30 PM
