Windows key in BIOS
  • brew99
    • Jan 2019
    • 132
    Windows key in BIOS
    So I thought I had saved the original BIOS dump from my laptop before I loaded another one. Apparently I didn't as when I opened up the .bin file to look at it, it was all 00. Does that mean that my original Windows key (Win8) is now lost, and there is now nowhere I can retrieve it? The BIOS I overwrote the original one has the Windows key blanked out (xxxxx-xxx etc.) and of course now Windows10 is saying it cant find the key.
    I guess I should be able to just purchase one if this one is now lost.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Windows key in BIOS
    There is no way now to recover the key. It was there in original dump but unfortunately backup is blank-so you need to buy another licence.
    • brew99
      • Jan 2019
      • 132
      That's what I figured, but thought I'd ask you more knowledgeable people. Thanks
        • 23697
        What make and model is the laptop, did you have driver update software installed .
        • brew99
          • Jan 2019
          • 132
          It's an Asus X541UA (mobo is X541UVK rev 2.0) with OEM Windows 8 (but I don't have the original HDD), which I purchased with a "no power" issue. Found a shorted cap on the 3V linear o/p, which I fixed, and then tried to do a dump of the BIOS, using a ribbon cable attachment to programmer as I initially didn't want to remove the IC, and this is where my blank dump occurred. First time doing this, so didn't really know what to look for. I now just remove the BIOS chip as I know it works fine that way.
          Anyhow, no problem guys, I have a working downloaded BIOS dump (just the key is "x" out, and I'll get a proper Win10 key to apply during the Win10 setup.
          • brew99
            • Jan 2019
            • 132
            I ended up obtaining a Win10pro key and inserting that into the bin file. Win10 grabbed it no problems and activated, so it looks like I'm good.
            Another question I have.....Is there some easy way to search a bin file in a Hex editor for the Win key if you don't know what the key should be? It was easy for me to find because the downloaded bin was all "xxx", but if it was a legit key, what could I search for?
            • caspian
              • Oct 2015
              • 1592
              • Laptop
              there is no straight-forward way to search it. you can write a simple C++ program that searches the bin file to find a few '-' that have occurred near each other.
              • khaahk
                • Dec 2013
                • 886
                • Estonia
                Depends on program, hexedit has wildcard option in text search. Also there should be a hex string in front of key: 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
                  • 23697
                  I scan for strings in the bios using FileAlyzer 2 ,made by spybot, and sort the strings by length.Its useful to find other dmi info too.
                  • brew99
                    • Jan 2019
                    • 132
                    thanks guys, I'll play with some of the mentioned tools and see what I can find
                    • brew99
                      • Jan 2019
                      • 132
                      So what are the ramifications of using a downloaded BIOS which has different MAC, mobo Serial#_Part#, and enclosure Serial#_Part#? I used RW Everything to look at the info
                      I've installed Win10 and put the key into BIOS, but now have noticed that most of the things I mentioned above are different numbers than what is physically on my mobo and computer case. It all still seems to work, just doesn't match up the the actual.
                      I'm guessing that if I changed it all in the BIOS, then Win10 will think things have changed and I'll no longer be activated?
                      Sorry if I'm being an idiot, just first time playing with a BIOS file
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Those are all DMI data. Dont change them as windows will definitely de-activated.
                        • brew99
                          • Jan 2019
                          • 132
                          Just out of curiosity, I did change all those parameters in the BIOS, and it is still showing "digitally activated" with my microsoft account. I haven't tried it with just a local account.
                          The only weird thing is the MAC address still shows something else, but in Win10 it has the correct MAC of the ethernet.
                          Anyhow, I might not understand this stuff, but it was something to play with
                          • brew99
                            • Jan 2019
                            • 132
                            So what is the proper way to ensure that the mobi s/n, Mac, Windows key, etc (Demi info I guess you call it) is not over written when you flash a dumped bios? Do you just ME region clean the dump before flashing?
                            Anyone have a link?
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3683
                              • slovakia
                              • hard-enduro
                              really nice tool
                              wonder how to search for what windows is that product key
                              • skysurf
                                • Apr 2015
                                • 21
                                • Portugal
                                that give the windows key right ?
                                and to find the serial number ?
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3683
                                  • slovakia
                                  • hard-enduro
                                  with windows 10 after activation, windows servers pair your config with license and next time activate windows itself even without product key in bios
                                  • TopPop
                                    Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                    by TopPop
                                    Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                    I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                    12-14-2025, 09:40 PM
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • abel2b
                                    Hello, Can anybody help with how to recover DMI and Windows Key from HP 14-DQ1004LA Bios
                                    by abel2b
                                    Can someone teach me how to edit New *.bin with DMI and Windows Keys from broken bios.
                                    where should I look (OFFSET) in old dump?
                                    What must be copied to make new functional bios?
                                    MY machine is:
                                    HP 14-DQ1004LA
                                    S.N: 5CD0080M17
                                    Background: Tea was spilled on my notebook accidently I imediatly, turned off, unplugged and opened to disconnect battery, I cleaned everything thoroughly, I checked all power supply coils for shorts and all good, except Vcore coil ohms at 0.1 ohms, but I searched around and it seems it is ok. I powered up the board , and all voltages...
                                    06-30-2025, 09:54 AM
                                  • 0xx
                                    2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                                    by 0xx
                                    Hi folks,
                                    My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                                    What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                                    I assumed that Windows Update was interrupted due to closing...
                                    09-14-2025, 03:46 PM
                                  • istvanszasz99
                                    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                    by istvanszasz99
                                    Product ID: RZ09-0421
                                    Motherboard: CH580
                                    Bios File Size: 32,768 KB
                                    Dear Forum Readers!
                                    !!! MY RAZER BLADE...
                                    11-24-2025, 05:52 PM
