Are RAM chips Interchangable?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Hello.
    I found that i have some 4GB DDR3 modules that are faulty, but it have shorted memory chips/one or two on module/. It gets really hot when pluged in and start. So i think if this chips from different manufacturers are interchangable. layout looks the same
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    Re: Are RAM chips Interchangable?
    No. Only if you have same memory chip, same characteristics.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      so chip must be from same manufacturer, series?
      • mosfetratus
        Sure Not
        • Feb 2019
        • 174
        • Resistron
        There are so many different factors, and finding a same equivalent from different manufacturer is challenging in IMO.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3628
          • slovakia
          and from same manufacturer? like from 2Gb modules
          • mosfetratus
            Sure Not
            • Feb 2019
            • 174
            • Resistron
            you can't just simply put any RAM ic.
            https://www.micron.com/products/dram...j4208efbg-gn-f
            https://www.micron.com/products/dram...m/part-catalog
            I doubt, you would find the same exact chip from different brand. Working exactly the same.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3628
              • slovakia
              offcourse i know it must have same parameters. but if the layout, capacity, speed and mumber of cips on module is the same, that it can work
              like i have two 4gb modules from different manufacturers, but both same speed, same clocking, same 2Rx8 layout, it can be interchanged?
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                No prediction can be made before actual replacement. Consider two desktop RAMs belonging to different manufacturers with the same clock/speed specifications. If I use them both on my desktop, it is possible that the RAM controller in CPU drop the working frequency. it is also possible that the two RAMs match each other and work perfectly. it is also possible that the RAM controller in CPU become unable to use the dual-channel mode.
                Such things may be possible. Since we have got no experience in RAM design/repair, we cannot predict what will happen exactly. But we can expect they may work at some frequency.
                • Icenesis
                  • Feb 2019
                  Caspian and Mosfetratus are both 100% correct with their assessment of your hypothetical ram repair!
                  How do you know exactly that the ram ic's are faulty? It could be smd caps that have turned leaky or a few smd resisters that have turned into jumpers.
                  You mentioned that 2 different modules could operate side by side with no trouble, but if you look closely at those modules, you see that in order to archive this combined cooperation, that the micro traces, capacitor as well as resister values are completely different.
                  For years I have replaced ic's and have had success but you have to be totally sure that your replacement ic has the exact pin out and specifications as the original. I haven't replaced one yet that I didn't have to modify components around it such as, values of caps, resisters, crystals or something.
                  My recommendation is unless you have a complete understanding, and an oscilloscope that I wouldn't attempt it. It is much cheaper to just purchase the memory you are having trouble with. Maybe later you'll come across another ram module that has the exact same ic's then you can attempt such a switch, even so, you could get a Hynix chip made 2 years ago and then one made today and they will have completely diff. values. Most chips are picked to match each other as close as possible by automated quality control equipment, and routed to a spooler. Then spools are sent to a ram module manufacturing dept. Didn't intend on writing a book but wanted you to understand that there's much more to switching components, it not like swapping PSU's. Hope this helps some.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    btw, i had 2 pcs 4gb pc3-l module with same symptoms and a particular chip was heating-i went ahead and replaced that chip from other defective ram(it was same 4gb pc3-L,same manufacturere,same chip) and it worked.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3628
                      • slovakia
                      Thats exactly what i asked
                      Did have that modules same timing?
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        i think that you will have no problems if you put chips with same timing or faster (thay should be downclocked in theory) but its best to put same chips from same manufacturer.
                        im in process of trying that in video card (vintage sdr and ddr1 graphic cards) in order to get better performance/overclock... but i havent tried yet... no time...
                        Im Back... sort of...
                        • mosfetratus
                          Sure Not
                          • Feb 2019
                          • 174
                          • Resistron
                          I have a ram module, that doesn't work, but not heating up. Could it be eeprom is damaged?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            yes
                            • ugamazing
                              Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                              by ugamazing
                              I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                              08-31-2022, 07:34 AM
                            • feherhollo
                              WSON8 NEW Bios Chips READ, ERROR, ETC.
                              by feherhollo
                              I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                              I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                              For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                              11-26-2023, 09:33 AM
                            • Prott
                              [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                              by Prott
                              Hello dear badcappers!
                              The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                              Backstory:
                              After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                              If there is a way to narrow down which memory module is faulty it would make my life much...
                              06-03-2024, 12:05 PM
                            • LukeDavis
                              Is there a list of known dodgy ATI Radeon chips?
                              by LukeDavis
                              Hello again! (People are likely going to get tired of seeing posts from me lol)
                              I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                              While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                              1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                              2. ATI Mobility Radeon X1600 and the...
                              02-16-2024, 04:34 PM
                            • piernov
                              NVidia bumpgate
                              by piernov
                              Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                              Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                              May complete this post at a later date with more details.
                              Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                              03-27-2021, 10:34 AM
