Hp - LA-A994P boot loop
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3609
    • slovakia
    Hello .
    Have this HP from my custommer that sudently stop and not work.
    Charging is ok, after power button start but after 4 seconds powerlight goes off
    i go through power on sequence on page 4 of schematic, but dont register that little low time after signal PBTN_OUT# goes on, and dont register any next signals.
    also found that CMOS battery have 0.0V i replaced it
    Now im trying to flash dumps. My rev is 2.0
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3609
    • slovakia
    Re: Hp - LA-A994P boot loop
    flashed all 4 bios dumps that i found here on forum but still the same
    • smali
      • Sep 2014
      • 287
      • Pakistan
      Have you check short on 3&5vs and all vs line on schematic page no29?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3609
        • slovakia
        yes, no short
        • khaahk
          • Dec 2013
          • 786
          • Estonia
          New cmos battery holds voltage ok?
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3609
            • slovakia
            yes, no problem with it.
            i try to manually start EC_SLP_S4 and EC_SLP_S3 signals but SOC start to BURN
            • NolesFan
              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
              by NolesFan
              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
              10-24-2024, 06:36 PM
            • Takeatry
              Yet another Samsung QLED Boot Loop
              by Takeatry
              Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
              10-04-2024, 02:57 PM
            • blaster_
              Samsung UE49MU6105K - boot loop, horizontal lines
              by blaster_
              Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
              Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
              06-22-2022, 05:19 PM
            • torchzack
              Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
              by torchzack
              Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
              I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
              Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
              08-28-2023, 07:42 AM
            • No Lan
              [Macbook pro A1708] [Boot loop] [Trackpad ?]
              by No Lan
              Hey everyone,
              Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
              Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
              Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
              05-24-2025, 03:09 PM
