Lenovo g50 usb problem
  • akande
    • Dec 2017
    • 278
    • Nigeria
    MY LENOVO G50 is not recognize usb devices bid :ACLU9?ACLU0 NM-A311 REV1:0ttached
    MY findings so far U2 IC pin1=0v,pin2,3=5v, pin4=0v pin5=1.7 pin 6.7&8=5v
    uei pin33=0v i need your help pls schematic attached
  • akande
    • Dec 2017
    • 278
    • Nigeria
    Re: Lenovo g50 usb problem
    schematics
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      looks ok. did u have installed usb 3.0 drivers?
      • akande
        • Dec 2017
        • 278
        • Nigeria
        i removed hdd , then try to boot the pc from a bootable flash driver not detected
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I think PIn4 should be 3V??
          • akande
            • Dec 2017
            • 278
            • Nigeria
            what next can do to fix the prob plz
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              i was think that "#" means that is active with low, like PWRBTN#
              • akande
                • Dec 2017
                • 278
                • Nigeria
                plz anyone i need to fix this usb prob
                • tonix
                  • Feb 2018
                  • 6
                  • zimbabwe
                  check the controllers near the usb ports
                  • akande
                    • Dec 2017
                    • 278
                    • Nigeria
                    that is U2 which the pin volt stated above
                    • akande
                      • Dec 2017
                      • 278
                      • Nigeria
                      someone help me out plz
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3627
                        • slovakia
                        in bios check option for usb
                        u r trying boot from usb 2.0 to usb 3.0 port so u must have been in compatible mode
                        • akande
                          • Dec 2017
                          • 278
                          • Nigeria
                          usb drive not found bios, which the pc not detecting flash drive
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3627
                            • slovakia
                            ok so buy a usb 3.0 drive and boot from it
                            • akande
                              • Dec 2017
                              • 278
                              • Nigeria
                              before this problem arise both 2.0 and 3.0 working fine all types of flash , now no one is working
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                You can try jumpering Pin4 of U2 with 3.3v but at your own risk.
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3627
                                  • slovakia
                                  better lift pin4 leg and inject 3,3V. this is without risk
                                  • akande
                                    • Dec 2017
                                    • 278
                                    • Nigeria
                                    Done no luck
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3627
                                      • slovakia
                                      what is measures after lifting and injecting?
                                      • ravenmx
                                        • May 2018
                                        • 179
                                        • puebla
                                        i have the same problem, i change u2, and u1, program bios, and it, and nothing works.
                                        • ravi_1617
                                          Lenovo B540 ,Starting Problem
                                          by ravi_1617
                                          Hello !
                                          Model Lenovo B540
                                          Board Details 09244-1
                                          LA14 DIS MB
                                          48.4DMO4.01.1
                                          This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
                                          when connected CMOS dont start.
                                          3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
                                          One more thing i want to mention ( by mistake i started at...
                                          10-14-2025, 02:08 AM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • s_specialist
                                          Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                                          by s_specialist
                                          Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                                          07-07-2025, 11:47 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • c.daniel
                                          Lenovo V310-15IKB weird bios problem...
                                          by c.daniel
                                          Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                                          sn LR09493E
                                          MB DAOLV6MB6F0 REV. F
                                          The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                                          Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                                          Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                                          08-22-2025, 05:39 AM
