Lenovo g50 usb problem
  • akande
    • Dec 2017
    • 278
    • Nigeria
    MY LENOVO G50 is not recognize usb devices bid :ACLU9?ACLU0 NM-A311 REV1:0ttached
    MY findings so far U2 IC pin1=0v,pin2,3=5v, pin4=0v pin5=1.7 pin 6.7&8=5v
    uei pin33=0v i need your help pls schematic attached
  • akande
    • Dec 2017
    • 278
    • Nigeria
    Re: Lenovo g50 usb problem
    schematics
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3590
      • slovakia
      looks ok. did u have installed usb 3.0 drivers?
      • akande
        • Dec 2017
        • 278
        • Nigeria
        i removed hdd , then try to boot the pc from a bootable flash driver not detected
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I think PIn4 should be 3V??
          • akande
            • Dec 2017
            • 278
            • Nigeria
            what next can do to fix the prob plz
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3590
              • slovakia
              i was think that "#" means that is active with low, like PWRBTN#
              • akande
                • Dec 2017
                • 278
                • Nigeria
                plz anyone i need to fix this usb prob
                • tonix
                  • Feb 2018
                  • 6
                  • zimbabwe
                  check the controllers near the usb ports
                  • akande
                    • Dec 2017
                    • 278
                    • Nigeria
                    that is U2 which the pin volt stated above
                    • akande
                      • Dec 2017
                      • 278
                      • Nigeria
                      someone help me out plz
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3590
                        • slovakia
                        in bios check option for usb
                        u r trying boot from usb 2.0 to usb 3.0 port so u must have been in compatible mode
                        • akande
                          • Dec 2017
                          • 278
                          • Nigeria
                          usb drive not found bios, which the pc not detecting flash drive
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3590
                            • slovakia
                            ok so buy a usb 3.0 drive and boot from it
                            • akande
                              • Dec 2017
                              • 278
                              • Nigeria
                              before this problem arise both 2.0 and 3.0 working fine all types of flash , now no one is working
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                You can try jumpering Pin4 of U2 with 3.3v but at your own risk.
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3590
                                  • slovakia
                                  better lift pin4 leg and inject 3,3V. this is without risk
                                  • akande
                                    • Dec 2017
                                    • 278
                                    • Nigeria
                                    Done no luck
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3590
                                      • slovakia
                                      what is measures after lifting and injecting?
                                      • ravenmx
                                        • May 2018
                                        • 167
                                        • puebla
                                        i have the same problem, i change u2, and u1, program bios, and it, and nothing works.
                                        • s_specialist
                                          Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                                          by s_specialist
                                          Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                                          07-07-2025, 11:47 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • konradx
                                          Lenovo Thinkpad T15 Touchscreen problem bios
                                          by konradx
                                          i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
                                          That is my DUMP.
                                          My device:
                                          SN: PF29Y4N6
                                          1s20S7S2WF00PF29Y4N6
                                          MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
                                          09-06-2024, 01:33 AM
                                        • madrali
                                          lenovo e15 gen2 bios ? problem
                                          by madrali
                                          Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                                          20TD-50S0KU00
                                          Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                                          I used Lenovo's SmartBeep decoder and it returned error 0284:
                                          "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                                          I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                                          06-16-2025, 12:06 PM
                                        • Ziome3eknh
                                          Lenovo x1 carbon problem
                                          by Ziome3eknh
                                          Hello, I have a problem with this computer.
                                          After connecting the power supply, the keyboard lights up and the touch bar works, you can click on it and it even illuminates the keyboard. When the fan is turned on, it turns on and off. the processor heats up. I have tried different bios but with no success, the same signs. It doesn't charge the battery either. when starting, it takes 20v and about 0.650a, after some time it drops to 0.350a and 5.2w. Has anyone solved the problem with this model?
                                          Will it be a RAM or CPU problem?
                                          below is the computer details
                                          Lenovo x1 carbon...
                                          01-29-2025, 02:35 AM
