Lenovo g50 usb problem
  • sadacomp
    • Feb 2019
    • India
    Re: Lenovo g50 usb problem
    Nm a311 usb port not working pin no. 4 per voltage Coming too still not working
    • hope1914
      • Oct 2020
      • 14
      • nigeria
      Please guys anyone with this solution. Someone said is the cpu
      • mon2
        • 14662
        What is the problem? Share full details.
        Same logic board? Same schematics?
        • ravi_1617
          Lenovo B540 ,Starting Problem
          by ravi_1617
          Hello !
          Model Lenovo B540
          Board Details 09244-1
          LA14 DIS MB
          48.4DMO4.01.1
          This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
          when connected CMOS dont start.
          3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
          One more thing i want to mention ( by mistake i started at...
          10-14-2025, 02:08 AM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • s_specialist
          Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
          by s_specialist
          Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
          07-07-2025, 11:47 AM
        • perzyk23
          Lenovo T580 - LCD Panel problem - error 0288
          by perzyk23
          Good morning,
          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
          10-25-2024, 12:42 AM
        • c.daniel
          Lenovo V310-15IKB weird bios problem...
          by c.daniel
          Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
          sn LR09493E
          MB DAOLV6MB6F0 REV. F
          The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
          Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
          Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
          08-22-2025, 05:39 AM
