Lenovo G40-70 backlight no image
  • maurovalero
    • Sep 2018
    • 69
    • colombia
    Hello, my laptop turns on and it has backlight but it shows nothing
    board aclu 1/2 uma nma272
    i did replace the memory ram, change the socket, probe new ram.
  • Jesse James
    • Sep 2018
    • 95
    Re: Lenovo G40-70 backlight no image
    Check connector to screen is secure
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3582
      • slovakia
      image on external display?
      • JaroTech
        • Mar 2015
        • 351
        Hi, if you have a white screen, then what voltage do you have on pin 21 of the screen connector (JEDP1) on the motherboard, you should have 3.3 VDC?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3582
          • slovakia
          he didnt wrote white display
          • taroo
            • Sep 2021
            • 16
            • myanmar
            I have same problem
            pin 21 3.3V OK please advice
            • taroo
              • Sep 2021
              • 16
              • myanmar
              White Screen Appear
              • andrhouseolly
                Lenovo X240 - motherboard replacement for X250, no image.
                by andrhouseolly
                Friends. I beg you to help me in this situation.
                Lenovo X240 with a video problem. Native Intel drivers are not installed,
                after installation, a black screen. It works with the standard Microsoft driver.
                Understanding that there are problems with the video core,
                I ordered a motherboard from Lenovo X250.
                The laptop turns on, starts up, there is no image on the internal display.
                The image is output to the external monitor.
                I ordered another motherboard from Lenovo X250.
                07-12-2024, 03:02 PM
              • Salem Aboshala
                820-00138-A got image but no backlight
                by Salem Aboshala
                Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                History: my laptop backlight stopped working without any reason.
                Symptoms:
                I have image on screen using my flashlight.
                I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                Keyboard backlight still working and can be adjusted normally.
                Since two days I tried to follow all similar...
                06-11-2024, 03:02 PM
              • marcelofct
                Lenovo Legion 15Ith6 no image
                by marcelofct
                I have this Lenovo Legion that only gives an image on the external screen
                I have tried several screens, flex cables, and nothing is detected in any way. I leave the following image so you can see the voltages and please help me.
                It is a lenovo Legion 15Ith6
                S/N: pf4f91at
                I appreciate it...
                02-01-2025, 10:53 AM
              • zaurus81
                Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                by zaurus81
                This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                The board is equipped...
                01-16-2025, 03:54 AM
              • techpointhull
                Lenovo V15 G3 No Backlight after liquid damage
                by techpointhull
                Good morning guys,
                I have a Lenovo V15 G3 that came in with liquid damage. The damage was very minor and some corrosion on the IO board where the power switch was. After cleaning both the motherboard and IO board in alcohol, the laptop turned on and I had backlight for about 3 seconds but nothing further. I don't have a boardview for this laptop (Have requested this in the Schematic Request section), however from previous experience on Lenovo laptops I have checked pins 1, 2, 3 on the EDP connector. When the battery is connected only, I get 8V and when AC adapter is connected, I get...
                11-28-2023, 01:57 AM
