Barely perceptible flicker on Pixelbook
  • Saturn49
    • Sep 2022
    TL;DR: Fixed a board by replacing the display connector and traces for the backlight. Now backlight sorta flickers.
    Side Note: This is mostly an exercise in stretching my troubleshooting and micro-soldering abilities - Pixelbooks aren't worth much, though I do have a replacement on order because my wife still uses it pretty often.
    Background: Coffee was spilled onto the display connector of a Google Pixelbook which (of course) managed to short out the display backlight. This burned the connector on the main board and the cable. In fact, it burned two pads for the connector too.
    So, some time later with a hot air rework I managed to salvage a display connector (and screen, cable, chassis, etc) from another dead Pixelbook (seemingly bad RAM or CPU, couldn't figure that one out). I also got a new wire run to the two backlight pins (2,3). How do I know they're the backlight pins? It is clear on the donor board they're connected together and I accidentally connected them to ground on my first attempt and the screen worked but the backlight did not. Anyway, everything works!
    Except...there's this slight flicker to the backlight. It doesn't turn off all the way, just flickers dimmer and brighter. Doesn't seem to be related to screen brightness (does it on low or high), and it doesn't do it all the time, but it does do it most of the time. It doesn't seem related to screen position, or physical movement of any sort.
    Three options:
    1) Display connector isn't making good contact. Despite my efforts with IPA, there's still a lot of (Amtech no-clean) flux in it. I could put the board in an ultrasonic cleaner, though I've struggled to get this flux off other things. How do people get this stuff off of boards, particularly from hard to reach places like inside connectors?
    2) My fix isn't great. Maybe too small of a wire, maybe only one of the two pins is making a connection. Maybe one pin is flaky. The size of these things (and lack of a microscope) is limiting my ability to test my work.
    3) Something else in the backlight circuit went bad during the Great Coffee Spill. Not sure how to go about finding that.
    4) Something else?
    Since I have a donor board, theoretically this is fixable, as long as the bad component isn't a BGA or something.
    Thoughts on where to go from here?
  • 5mall5nail5
    Help identifying connector for ASUS 4090 Strix RGB LED connector
    by 5mall5nail5
    Hi All -
    I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
    Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
    05-04-2025, 07:47 AM
  • bussincaps
    MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
    by bussincaps
    Hello All,
    tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
    Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
    eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
    Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
    I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
    08-03-2023, 12:57 PM
  • michhak
    Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
    by michhak
    Hi guys,
    i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
    It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
    11-17-2021, 05:45 AM
  • m1ch43lzm
    70mai Dash Cam A510 - help identifying connector on camera module
    by m1ch43lzm
    Hi everyone
    I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
    The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
    I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
    05-11-2025, 06:02 PM
  • reformatt
    LCD Connector identify or source
    by reformatt
    Trying to identify where to source the LCD connectors on the motherboard side for a HP 14-cf2051la. This one came in with liquid damage to the connector and the flex cable. It appeared to clean up ok, however customer says that display blanks out intermittently. It's a 30 pin EDP flat ribbon cable on motherboard side. Believe it to be a HEDWIG-6050A3155301-MB-A01 motherboard.
    I've stolen the connector from another HP motherboard which matches up but it's not the best since it's been kicking around my donor pile for a while. This connector is different to most flip type ones I have...
    03-25-2024, 08:29 PM
