Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • rccrasher65
    • Mar 2014
    • 625
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    Power adaptor arrived, and its defective, waiting for RMA. just about had it with this. I guess back to looking for a replacement. TKO doesn't have any more.
    • BlueMidnight
      • Jan 2015
      • 489
      If you haven't already, do make sure to test the AC adapter without plugging it into the motherboard.
      Start with the AC adapter fully unplugged, then plug it into the wall and measure the voltage directly on the plug. Ground is the outside of the barrel and positive is the inner surface. Touching the center pin won't hurt anything (it just goes through a resistor to positive), but if you aren't also touching the inner surface with the probe, you'll probably read at least a volt less than expected (depending on the internal impedance of the multimeter).
      • rccrasher65
        • Mar 2014
        • 625
        I checked it like you said, and i'm not getting 19V, just like the other one did. also checked my multi meter, changed battery also, same results. Going to try and find a used original.
        • rccrasher65
          • Mar 2014
          • 625
          Ordered an OEM original, but its used, nothing out there but junk. Should arrive on the 9th, maybe then I can start to fix this junk laptop for the last time! Thanks for your patience BlueMidnight!
          • BlueMidnight
            • Jan 2015
            • 489
            Alright. No problem.
            • rccrasher65
              • Mar 2014
              • 625
              Another defective adaptor, I think i'm just going to purchase another laptop.
              • BlueMidnight
                • Jan 2015
                • 489
                Heh well that's certainly one way of resolving it.
                • rccrasher65
                  • Mar 2014
                  • 625
                  found another, maybe Ill give this one last shot, still looking for a new laptop, any suggestions, no macs!
                  • rccrasher65
                    • Mar 2014
                    • 625
                    finally got a good Oem original charger. going to read through the thread, and start some basic tests, have two boards to repair.
                    • rccrasher65
                      • Mar 2014
                      • 625
                      misplaced dc power jack, need to order one, will do basic tests and post results.
                      • rccrasher65
                        • Mar 2014
                        • 625
                        Blue Midnight you avaliable to walk me through another board repair?
                        • BlueMidnight
                          • Jan 2015
                          • 489
                          I'll see what I can do. I'd recommend starting a new thread to describe the problem if you haven't already.
                          • rccrasher65
                            • Mar 2014
                            • 625
                            same board, same problem. I will go through this thread and test what you have told me previously. Let you know what I find. Thank you!
                            • BlueMidnight
                              • Jan 2015
                              • 489
                              Alright. Hopefully something straightforward.
                              • rccrasher65
                                • Mar 2014
                                • 625
                                Testing this evening after work, thanks
                                • rccrasher65
                                  • Mar 2014
                                  • 625
                                  Got some results for testing PL inductors. PL-25, 47.2 ohms, PL-16, 9.37K ohms PL-15, 65.6K ohms PL-12 27.89K ohms PL-11 169.9K ohms PL-18 16.1 ohms PL-17 28.1 ohms PL-21 21.1 ohms PR-103 3.97M ohms PL-6 22.87K ohms PL-1 1.369K ohms Will test other components later as my needle broke off of my meter probes, got to solder it back on.
                                  • BlueMidnight
                                    • Jan 2015
                                    • 489
                                    So far nothing looks unusual. As a general rule, regular power rails should be in the kΩ range or higher, while CPU/GPU rails should be down around where your readings are (due to the leakage current from the huge number of transistors inside such devices).
                                    • rccrasher65
                                      • Mar 2014
                                      • 625
                                      Ok, good I'll finish with the other components, PQ5, and PQ9.
                                      • rccrasher65
                                        • Mar 2014
                                        • 625
                                        PQ9 results: Source to drain Pin1-0.535V , pin2-0.534V pin3-0.512V with opposite OL on all 3 pins. Gate to source all pins reading OL, no continuity! same with gate to drain, all pins OL, no continuity.
                                        PQ5 results: Source to drain Pin1-0.435V, Pin2-0.438V pin3-0.439V opposite OL on all three pins. Gate to source, and gate to drain all pins OL, no continunity. What would be next step?https://www.badcaps.net/forum/images/smilies/poof.gif
                                        • BlueMidnight
                                          • Jan 2015
                                          • 489
                                          Let's check the AC adapter. I think I mentioned this early in the thread, but I'll say it again. Plug it in and measure between ground on outside of the barrel and positive on the inside of barrel. It's okay to touch the center pin as long as you are also touching the inner surface of the barrel (otherwise you will probably get a reading that is about a volt too low).
                                          As long as the voltage is within reason (~19.5 volts) and stable, continue...
                                          Next, let's check some of the voltages with the power supply plugged in.
                                          Measure the voltage at the following components. You only need to measure one pin from each:
                                          PR103 (main +VIN power rail)
                                          PL12 (3V switching regulator output)
                                          PL15 (5V switching regulator output)
                                          Let's also check the 3V (+3V_ALW) and 5V (+5V_ALW) linear power rails, as well as the AC adapter identification signal (LIMIT_SIGNAL). See attached pics. Note that the arrow is pointing to one specific side of the indicated component.
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • someonenotyou
                                            HP ProBook 445 G7 no POST only on battery
                                            by someonenotyou
                                            Hi.
                                            I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                                            When I attach DC Jack, the laptop will charge the battery and switch on.
                                            And now the strange part:
                                            1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                                            2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                                            06-30-2025, 01:24 AM
                                          • Jacksoft
                                            HP ProBook 440 G6 infinite orange blinking
                                            by Jacksoft
                                            I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
                                            The PC worked but it was very slooow to show HP logo in first place.
                                            A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
                                            The laptop doesn't power on anymore, and the blinking led happens...
                                            08-29-2025, 01:24 AM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
