Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • BlueMidnight
    • Jan 2015
    • 489
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    I agree. PQ5/PQ9 have no signs of a short.
    One more thing I can think of is to confirm resistance to ground on +VIN. You can measure that at PR103 (doesn't matter which side since it's only 0.01 ohms), or at the drain of PQ9 instead if you'd prefer.
    If that resistance looks good, then it may be time to replace PU20.
    • rccrasher65
      • Mar 2014
      • 625
      PR103-29.05 m ohms Gate of PQ9- 28.42 m ohms
      • BlueMidnight
        • Jan 2015
        • 489
        I assume that is megaohms and not milliohms. Megaohms is just fine and would mean the next best step is to replace PU20 with another BQ24780S.
        • rccrasher65
          • Mar 2014
          • 625
          Yes mega ohms.
          • BlueMidnight
            • Jan 2015
            • 489
            You can get BQ24780S from all the same places you could get the capacitor. The full/long part number may end in "RUYT" or "RUYR", but that's just the quantity it was packaged in when it left the factory, and not any difference in the chips themselves.
            You also have one on your other spare board, obviously. But you may prefer to leave well enough alone when it comes to that.
            • rccrasher65
              • Mar 2014
              • 625
              I'm, just gonna try and order a few from Digi key, their web page is very confusing, so I'll just call,and tell them what I want. Any tips on changing that chip out, I've done a few of the 144pin HDMI chips, but they are much bigger.
              • BlueMidnight
                • Jan 2015
                • 489
                On DigiKey you can search for "BQ24780S" and you'll get several results. Some are entire factory reels or made-to-order reels by DigiKey, or otherwise have a minimum quantity. So you just find the cheapest one they are willing to sell in quantities of 1 or more ("1" in "Minimum Quantity" column), and have in-stock (number available plus the word "Immediate" in "Quantity Available" column).
                Which would be this.
                Obviously, this part needs to be removed and attached with hot air. You remove it, clean the pads with desoldering braid, and then tin the pads (lightly) with new solder. Then, position the new part, heat it, and wait until the solder melts and the part should self-center on the pads. If you need to reposition it, push it down flat against the board, or break any solder bridges, use a stainless steel implement (like a dental pick).
                Flux is essential for this to work well. Good flux means clean metal, which means solder sticks well, which means the surface tension pulls the solder tightly to the metal. This makes a solid joint as well as discourages solder bridges from forming between neighboring pins (extra important when the part has pads underneath the chip that you can't see while soldering, like this one does). And it can't be liquid flux (like the sort that comes in flux pens) that is going to evaporate in a second, or that brown/orange stuff that is solid at room temperature. It should be a decent gel-type flux that will stick around through the whole process. A little rubbing alcohol will clean up the residue afterward.
                Louis Rossmann has a bunch of videos on YouTube. The majority of them will have a chip like this being soldered. And they have a good, clear image. He does like to put too much solder on and then clean up the solder blobs after, though. It works for him. But, I prefer to use far less solder so it can be a single step process.
                • rccrasher65
                  • Mar 2014
                  • 625
                  Ordered today, that one was same one I chose also, with a little help from Digi key. I will remove PU20, and clean pads, and tin also. I do enjoy watching Louis, someone with his skills and knowledge, would make a killing here in Pgh. I have all the things necessary to replace this chip, hopefully skills will kick in. I have replaced those 144pin Hdmi chips, but they are much bigger. Let ya know what happens, thanks again, enjoy your tutorials.
                  • rccrasher65
                    • Mar 2014
                    • 625
                    Removed PU-20, cleaned pads and re tinned. Now just waiting for new chip to arrive in a few days. Will watch some Vids on placing those kinds of chips.
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      Alright, good luck. The last bit of advise I can give is to inspect the edges of the chip carefully with decent magnification after doing the work. Look for solder bridges and proper centering of the chip before attempting to apply power.
                      • rccrasher65
                        • Mar 2014
                        • 625
                        Ok, thank you again for all your help, will let you know how it goes.
                        • rccrasher65
                          • Mar 2014
                          • 625
                          New chips have arrived. Will give it my best attempt to replace.
                          • rccrasher65
                            • Mar 2014
                            • 625
                            Well things didn't go so good, while cleaning the old solder from the board, my solder braid must have pulled pin 3 pad off, its not shiny like all the others, a brownish color under scope. I tried to tin, but still the same. I guess board is junk now.I don't know if chip would function without pin 3.
                            • BlueMidnight
                              • Jan 2015
                              • 489
                              I suppose even that scenario is a learning experience in itself. Lifted pads are generally caused by either too high a temperature, too much time dwelling on that pad, and/or too much force being applied to it. It can also be caused by corrosion of the pad, but usually you can tell when an area has been subjected to that.
                              But all is not lost. It can still be repaired.
                              If you can get the rest of the pins soldered successfully, then a thin wire can be run directly from pin 3 to where it needs to go.
                              You can pre-tin one end of the wire, and then stuff it under pin 3 of the chip and heat the solder. The other end of the wire goes to the right side of the resistor indicated in photo #8.
                              • rccrasher65
                                • Mar 2014
                                • 625
                                I checked my iron temp 480C. It was my fault completely, I got braid to stick, wasn't gentle with it, pulled a little to hard, surprised more didn't come off. Good thing I only payed $10.00 for board. I will try to repair this, What size wire you recommend? I definately don't have anything that small. You want me to put that wire on before chip is set, or after chip is set.Either way its gonna be nearly impossible.That's why I'm here to learn from my mistakes.
                                • BlueMidnight
                                  • Jan 2015
                                  • 489
                                  After the chip is in place, you can attempt to solder the wire by using the iron with a thin tip.
                                  The diameter of the wire isn't critical from an electrical standpoint. It will draw very little current.
                                  The width of the pins on the chip are 0.2 mm, which corresponds to roughly 32 AWG. Going slightly larger may be possible, but going too large risks creating solder bridges with the neighboring pins. There is only a 0.1 mm gap between the pins. I'd say don't go any larger than 28 AWG, but smaller may be necessary.
                                  There is a slightly different technique you could attempt if you wish. If the trace going to pin 3 is still there, it is possible to scrape off the green solder mask covering the trace with the point of a knife until you see bare copper (being careful not to remove any solder mask covering neighboring traces). Then, you can solder a short bit of bare wire between pin 3 and the trace. So basically, this bit of wire would be laying directly on top of the trace (the more of the trace, the better), pushed up against the side of the chip, and covered completely with solder along its length.
                                  Which technique is easier probably comes down to personal taste. But, little bits of wire like that tend to get sucked up into the solder on the iron tip the same way other small components do. So it might get frustrating trying to position it if you're not used to that. It is a more robust repair though, since soldering a long wire directly to the chip pin doesn't give it as much surface area to hold onto. Plus it can break off if it flexes back and forth too much.
                                  • rccrasher65
                                    • Mar 2014
                                    • 625
                                    I'm pretty sure the trace is intact, and just the pad was pulled off. I will try to cut away the solder mask on top to expose the copper, that would be the best for me I think, either way, I don't think I'll be successful in getting the board to work again, just don't have the skills to make a repair like this, I can barely see, pins as small as those are. but I will give it my best shot. Still a great learning experience, and thanks for taking time out of your day to give a noob a hand.
                                    • rccrasher65
                                      • Mar 2014
                                      • 625
                                      Donor board now, Thanks BlueMidnight for all your help!That kind of repair way beyond my skill set, just too small!
                                      • BlueMidnight
                                        • Jan 2015
                                        • 489
                                        Beyond your skill set.. for now :P Even a failed attempt is still a learning experience. Maybe next time.
                                        • rccrasher65
                                          • Mar 2014
                                          • 625
                                          Thank you Sir for all your time and Patience, 2 out of 3 isn't bad though, couldn't have done it without your help, Thanks again!
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • someonenotyou
                                            HP ProBook 445 G7 no POST only on battery
                                            by someonenotyou
                                            Hi.
                                            I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                                            When I attach DC Jack, the laptop will charge the battery and switch on.
                                            And now the strange part:
                                            1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                                            2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                                            06-30-2025, 01:24 AM
                                          • Jacksoft
                                            HP ProBook 440 G6 infinite orange blinking
                                            by Jacksoft
                                            I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
                                            The PC worked but it was very slooow to show HP logo in first place.
                                            A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
                                            The laptop doesn't power on anymore, and the blinking led happens...
                                            08-29-2025, 01:24 AM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
