Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • BlueMidnight
    • Jan 2015
    • 489
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    Alright, it's not going to give up its secrets that easily. So when you get your power supply, it's going to go as follows:
    - Set a voltage limit of 3V.
    - Start current limit at 0.
    - Either clip the ground lead to a screw hole at the edge of the board, or solder a wire to a suitable ground point and clip the ground lead to the wire instead.
    - Solder a wire to the PL12 pad that still measures as shorted (or reattach PL12 and solder directly to PL12 itself), and then clip the positive lead to that wire.
    - Slowly ramp up the current.
    The actual voltage shouldn't even reach your limit since the resistance is too low. But it will edge up slowly as the current increases.
    We don't know where the short is, so we don't know how much current will be required to find it. If a small component (like a surface mount capacitor) is shorted, then it won't take much power to get it hot. But if a larger chip is the culprit, then it might take a lot more to get it warm.
    I'd say set it to 100mA. And if everything looks good, starting moving it up to 500mA, 1A, 1.5A, etc. At each level you must touch every single little component (including the tiny surface mount parts) on the board to see if they are getting warm.
    If you narrow the warmth to a small area, but can't decide which component is the source of the heat, you can use drops of isopropyl alcohol. The warmest spot will be where it evaporates first.
    No heatsink is required during this test.
    • rccrasher65
      • Mar 2014
      • 626
      I'm hoping my dc supply will arrive on Monday, in the meantime, I will prep the board with those wires on ground and PL12, shorted side.Lets hope its something nice and easy to find.
      • rccrasher65
        • Mar 2014
        • 626
        Power Supply arrived, I found the little trouble maker. first tiny resistor, next to the 144pin chip. resistor got hot as hell. its right next to the large circle on the chip. will load a pic but don't know how to mark the resistor.
        • rccrasher65
          • Mar 2014
          • 626
          I can't seem to load my picture, On pic 3, the 144 pin chip. There is a large circle on the left side of the chip. Its the first tiny resistor next to the first pin of the chip on the left hand side of the chip. Will continue to try and load my picture.Going to put PL12 back on board. I would assume you will want me to remove that small resistor to see if short goes away.
          • rccrasher65
            • Mar 2014
            • 626
            I got it to load.
            • BlueMidnight
              • Jan 2015
              • 489
              I'm not sure if you are using your phone, PC, etc, to upload things. On the PC, I use FastStone Image Viewer ('D' key) or IrfanView ('F12' key) to do annotations, though it can be done in Paint or other similar apps too.
              You can also use the boardview posted earlier to find the name of the hot component.
              Pointing works just fine too. Heh
              Actually, that is a capacitor with the identifier C550. That's a good thing. A resistor getting hot is harder to explain. But that capacitor does indeed go from the 3.3V rail to ground.
              And you guessed right. Let's remove it and see if the short goes away.
              • rccrasher65
                • Mar 2014
                • 626
                Yes I'm using my phone for now. It wasn't badcaps, It was my phone not letting me connect with my computer. I'm not very good with a computer, I'm lucky I can get what I'm giving you now. I will place PL12 back on board, and remove that cap. Where do you source a replacement? I have never had to replace something that small before.
                • BlueMidnight
                  • Jan 2015
                  • 489
                  You can easily find all those simple components (caps/resistors/etc) at DigiKey or Mouser. They will also be on eBay and such, but with less certainty as to their true manufacturer. Since they are unmarked, you have to trust the seller to identify them honestly.
                  C550 is a 10uF 6.3V ceramic capacitor in a 0402 (roughly 0.04in x 0.02in or 1mm x 0.5mm) package. Ceramic capacitors also have ratings for temperature low/high/stability. The schematic doesn't say for this one, but "X5R" will be good.
                  • rccrasher65
                    • Mar 2014
                    • 626
                    I reset PL12, and removed the bad cap. short is no longer there. PL12 now measures on both sides 26.98K ohms. Can you attach the link to what I exactly need from Digikey I have never ordered anything that small, and there site is very confusing.
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      This one will do nicely.
                      • rccrasher65
                        • Mar 2014
                        • 626
                        Ordered, Thank you very much. I'll let you know when it arrives, purchased a few extra.
                        • rccrasher65
                          • Mar 2014
                          • 626
                          I do believe caps should arrive on Fri or sat at the latest, any tips on placing that small cap on board. I do have Amcap, a microscope pen camera. that will magnify the board. I guess hot air would be best.
                          • BlueMidnight
                            • Jan 2015
                            • 489
                            For really small components like this, they come right off with a soldering iron to just one side. For larger components, hot air is needed to remove them.
                            But when it comes time to attach components, hot air is usually not desirable.
                            I only use hot air to reattach things with pads/balls underneath, like power FETs or BGAs, because then you really do have to heat up the whole component to solder-melting temperatures. It's just more wear and tear on the PCB than is necessary for other things. And tiny components will just want to blow away.
                            For most components (again, without pads/ball hidden underneath), just clean off the pads with desoldering braid (being extremely extremely careful not to accidentally pull off any neighboring components. Gently hold the new component in place, flat on the pads, and tack down a couple pins with your iron. If there are remaining pins, it is now easy to solder those as well.
                            • rccrasher65
                              • Mar 2014
                              • 626
                              Okay I'll give that a try, I have 10 so if I happen to make a mistake I'll have more to try again.
                              • rccrasher65
                                • Mar 2014
                                • 626
                                Caps are due in on sat, I will get one on board as you suggested using the iron instead of hot air. Hope I can see that little bugger.
                                • rccrasher65
                                  • Mar 2014
                                  • 626
                                  Had to order some new soldering iron tips, smallest I had was to big, should arrive on tues.
                                  • rccrasher65
                                    • Mar 2014
                                    • 626
                                    Well 6 hrs and 2 caps later I finally got that little shit on the board. I hope all this will be successful. I guess we are ready for next step.
                                    • BlueMidnight
                                      • Jan 2015
                                      • 489
                                      Those little components do like to jump around all over the place, get sucked up by the iron tip, and other mischief.
                                      At his point, you can try connecting the AC adapter to insure that you get 3.3V on that rail (at PL12).
                                      If you do get 3.3V while the board is plugged in, then you can try turning on the board. The equivalent to a power button press is shorting together pins 3 and 4 of connector CN5 (where the power button cable normally plugs in) for a moment.
                                      The heatsink/fan should be attached for this test.
                                      If the fan spins, then that's at least a good sign. But you will need to install the board in the notebook to test it fully, obviously.
                                      • rccrasher65
                                        • Mar 2014
                                        • 626
                                        Those little caps drove me crazy, doing everything you said, and more. But I finally used hot air turned down to 5 on air flow, finally attached itself. cleaned board. I placed a 1in x3in alum, heat sink on chip and applied power. fan did start to spin. I guess Its time to start pulling apart my laptop to fully test. I will do that and get back to you with all the results. I want to THANK you for the learning experience, I've enjoyed every step of the way, and learned a lot. I d efinately owe you one, and truely appreciate all your help, Thank you again.
                                        • rccrasher65
                                          • Mar 2014
                                          • 626
                                          I installed repaired mother board, and Its working like a charm, Many thanks to Blue Midnight, I cant begin to thank you enough for walking me through my first component level repair. All seems perfect, Its asking for an Operating system just like the replacement did. Ill have to find a good windows 10 operating system, as I have no recovery disk with this lap top. If you happen to know how to get one, please let me know. A friend of mine set this up the last time for me, but he is out of town for over a month on business. Again thank you for all your help, you truely are a master at what you do, many thanks, George
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • someonenotyou
                                            HP ProBook 445 G7 no POST only on battery
                                            by someonenotyou
                                            Hi.
                                            I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                                            When I attach DC Jack, the laptop will charge the battery and switch on.
                                            And now the strange part:
                                            1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                                            2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                                            06-30-2025, 01:24 AM
                                          • Jacksoft
                                            HP ProBook 440 G6 infinite orange blinking
                                            by Jacksoft
                                            I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
                                            The PC worked but it was very slooow to show HP logo in first place.
                                            A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
                                            The laptop doesn't power on anymore, and the blinking led happens...
                                            08-29-2025, 01:24 AM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
