HP laptop board DA0R62MB6E0 REV. E
  • eniac22
    • 124
    • Greece
    I have this mainboard DA0R62MB6E0 REV. E from hp laptop, no power up no light.
    I messure on PU5 this voltages
    pin ---> voltage
    1,2,3 -> 18.6V
    4 -> 24.5V
    5 -> 2.9V
    6 -> 2.6V
    7 -> 0V
    8,9,10 -> 5.1V
    11,12 -> 1.2V
    13--> 12V
    14, 15 --> 0V
    16 ---> 6V
    17 ---> 5.9V
    18,19 ---> 1.2V
    20 ----> 18.7V
    also on all pins on power button except ground i get 5V, it's normal this?
    It's worth continue troubleshooting or not?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: HP laptop board DA0R62MB6E0 REV. E
    Mesure Voltage pin 19 KBC KB3940QF
    Mesure Voltage PU9 pin 6
    What are the Voltage of the battery connector
    • eniac22
      • 124
      • Greece
      KBC pin 19 --->5.09V
      PU9 pin 6 ----> 5.1V
      PU10 pin 6 ----> 5.1V
      Battery pin 1, 2 --->2.32V
      pin 3,4 ---> 5.08V
      pin 6 ---> 5V
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Change PU9 that's your 3V LDO +3.3VS5_ convertor it shouldn't output 5V LDO must be 3.3V
        PU10 pin 6 Voltage?
        • eniac22
          • 124
          • Greece
          pu10 is 5.1v, pu10 is 5.1v, i must find the same exactly chip or can i use a similar
          Thanks i will try and replay
          • eniac22
            • 124
            • Greece
            Still trying to repair this laptop
            KBC pin 19 --->3.33V (prev was 5.09V)
            PU9
            pin 1----->19.63V
            pin 6 ----> 3.33V (prev was 5.1V)
            pin 10----> 4.81V
            pin 11----> 5.16V
            pin 12----> 5.56V
            PU10
            pin 1----->19.63V
            pin 6 ----> 5.05V
            pin 10----> 4.83V
            pin 11----> 5.16V
            pin 12----> 5.42V
            Battery pin 1, 2 --->2.91V (prev was 2.32V)
            pin 3,4 ---> 3.33V (prev was 5.08V)
            pin 6 ---> 3.27V (prev was 5V)
            pu5
            pin:
            1,2,3 -> 19.62V
            4 -> 25.4V
            5 -> 2.98V
            6 -> 2.73V
            7 -> 0V
            8,9,10 -> 3.33V (prev was 5.1)
            11,12 -> 2.88V (prev was 1.2V)
            13--> 2.88V (prev was 12V)
            14, 15 --> 0V
            16 ---> 6V
            17 ---> 5.9V
            18,19 --->2.88V (prev was 1.2V)
            20 ---->19.62 (prev was 18.7V)
            I have 3.3V on power button and going to 0 when press the button but nothing happens, also i don't have a light on the power cable
            • piernov
              • Jan 2016
              • 4439
              • France
              On HP laptops, AC adapter must be recognized before the laptop turns on, so you need to get a light on the DC-in jack.
              As your 3.3V rail was up to 5V, it may have killed the EC. Probably a good idea to replace it. You can also try to flash EC ROM.
              You can also check voltage on AD_ID and AD_TYPE, it's the voltage level that tells the EC what AC adapter is plugged in.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                if you jumper the AD_ID to the +3vpcu will it get damage?
                What if your not having a EC_PWROK and RSMRST#?
                will it be a bios issue ? or a ENE CHIP issue?
                ACIN is 3v
                EC_PWROK no voltage
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Start your own thread with full description of problem and steps you have taken so far.
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                    Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-07-2024, 06:11 AM
