hp 14-am096tu system fan error 90b
  • Romy2018
    • Sep 2018
    • 174
    • japan
    I need help on this hp 14-am096tu laptop cannot boot because it has an error of system fan error 90b, i check the fan and removed in the board and check with bench lab by injecting on + and - 3v the fan is spinning. anyone help on this
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: hp 14-am096tu system fan error 90b
    connect the fan to the laptop and just look at the fan when it turns on. then, tell us how the fan behaves during power on and after that.
    • Romy2018
      • Sep 2018
      • 174
      • japan
      i connect the fan to board and turn on and observe the behavior, the fan is not spinning and also it takes 8seconds to display, and also cannot detect hard drive.
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        the fan seems to be healthy and the problem is probably from something else on the mainboard, such as Bios or EC firmware.
        • Romy2018
          • Sep 2018
          • 174
          • japan
          i will try to flash the bios does someone have a good working bios for this please help
            • 20789
            There are 6 different bios for the 14-am series, i posted all the bios in a new thread: https://www.badcaps.net/forum/showthread.php?t=73759
            Backup your bios first, find your BID number ,flash the bios.
            • Romy2018
              • Sep 2018
              • 174
              • japan
              thanks smdflea. I tried flashing the bios still the same issue system fan error 90b and cannot detected hard drive.anyone who encounter this problem please help
              I have uploaded original dump
              • Romy2018
                • Sep 2018
                • 174
                • japan
                anyone can help me on this please
                • Romy2018
                  • Sep 2018
                  • 174
                  • japan
                  anyone can help on this tried everything but still system fan error 90b and cannot detected hard drive
                  • zpi
                    • Feb 2018
                    • 132
                    • Lithuania
                    Does your HDD get power ? (Does it starts to spin?). I believe same 5v needs to be present for fan and hdd. Are your USB ports working ?
                    • Romy2018
                      • Sep 2018
                      • 174
                      • japan
                      the hdd not get power and not start to spin same with fan.all usb ports are working ill tried to boot on windows installiotion on flash drive and its detected fine.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3582
                        • slovakia
                        fan is driven from its driver through mosfet. so check driver signal and what do mosfet
                        • Romy2018
                          • Sep 2018
                          • 174
                          • japan
                          I still not solved this problem but i found a clue on this two caps near fan connector there is no 5v and on the other side the one cap near the hdd connector has no 5v also and then this cap is connected to the two caps near the fan connector.but when i reheat the two caps it works and after shutdown and leave the laptop for a couple of hours and tried again i came back to the same issue.anyone could help me on this please!!! i have upload the image
                          • Romy2018
                            • Sep 2018
                            • 174
                            • japan
                            anyone please help on this please
                            • Romy2018
                              • Sep 2018
                              • 174
                              • japan
                              i found a 5 leg chip near on dvd connector the pin with the red marked is connected to the caps on the hdd and fan side if you inject 5v there the fan spins
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3582
                                • slovakia
                                dont have schematic?
                                check datasheet of that chip what it make and check for voltage on pins
                                • Romy2018
                                  • Sep 2018
                                  • 174
                                  • japan
                                  i cannot find schematic on this model
                                    • 20789
                                    At post #13 you said it worked when you heated the 2 caps, take a picture of that area. Try and trace where those caps go ,if theyre connected to some IC post the part number .
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3582
                                      • slovakia
                                      u have to find 5V switch. maybe it is that ic . u must check its datasheet
                                      reheat caps???
                                      • on/off
                                        • Oct 2016
                                        • 333
                                        • Indonesia
                                        Would be helped if know mobo code. although there is no schematic at least should find a schematic that is quite close.
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • Maalobs
                                          Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
                                          by Maalobs
                                          I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
                                          The relevant service manual for the chassis is available here.
                                          The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
                                          When I short the SDM to ground I get the layer-2 error code 53.
                                          The inside of the TV has no damaged components and no swollen capacitors.
                                          In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
                                          04-02-2019, 01:15 PM
                                        • medinfo
                                          Mac T2 after update(There was an error activating your device)
                                          by medinfo
                                          Macbook Pro 2019 T2
                                          iCloud OFF
                                          MDM unlocked by changing Serial Number
                                          worked fine but after latest update see (There was an error activating your device. Please try again).
                                          Erased and boot in internet recovery, same error.
                                          changed to original serial number (iCloud OFF & MDM ON), same error.
                                          tested with others serial number, same error.
                                          tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
                                          Revived and restored by Apple Configurator and same error.
                                          Any help ?
                                          12-31-2023, 02:04 PM
                                        • rmjimenez455@gmail.com
                                          Sumsour station 8586D error H-E
                                          by rmjimenez455@gmail.com
                                          Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                                          09-07-2024, 09:33 AM
