M961 mbx-224 rev 1.1 no power
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Im not getting any 19v in the pin 5,6,7,8 pin ? why does this problem occur?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: M961 mbx-224 rev 1.1 no power
    DC in PCN2 pin 12 connect with Fuse PF1 you should get 19V their if you have 19V over there the move to PL1 PL2 both side 19V if no voltage one of the 3 components short
    After test cap PC123 PC125 PC126 PC20 PR133 PR138 (with power and without in resistance mode)
    send a feed back
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      You didn't mention any component. ICs or Mosfets?
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        I dont have 19 v in pq2 sorry
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          I have 19v in tp190 but in PQ2 mosfet in pin 5,6,7,8 I dont have any voltage
          • Techtiger
            • Oct 2014
            • 1602
            • france
            BQ24753 (PU3) IC Voltage in Pin2.3.4.5.13 ?
            PQ 2 voltage in Pin 123 4 ?.test your mosfet out of the Mob in Diode mode
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              If you have lab power supply, inject some voltage on pin5-6-7-8 of pq2 and see if anything gets hot. You are most likely having short in B+ line.
              • zpi
                • Feb 2018
                • 132
                • Lithuania
                Check if you do not have short to ground on pin 5, if you dont, then short pin 1 to pin 5.
                • sparrow2719
                  • Oct 2015
                  • 69
                  • Indonesia
                  Check pq1 and pq2 for short.
                  Check the pin 4 on pq1 and pq2, it is driven by ACDRV# voltage PU3
                  If there is no voltage on ACDRV# the pq1 and pq2 will not conduct and passing the voltage.
                  • khaahk
                    • Dec 2013
                    • 812
                    • Estonia
                    Those are P-channel mosfets.
                    • sparrow2719
                      • Oct 2015
                      • 69
                      • Indonesia
                      Uups my bad, didn't see the arrow mark pointed out on pq1 and pq2...
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        03-31-2024, 02:12 PM
                        09-06-2024, 05:59 AM
