GTS 250 GPU short circuit
  • Sraros
    • Jan 2017
    • 223
    • Greece
    I have a GTS 250 with short that goes all the way to the power connector and shuts down PSU for safety. Fan spins for a while then shuts down. I tracked down one of the mosfets is shorted. Pulled it out and now the short seems to disappear. At least I am getting 12V at the power connector and the PC starts again.
    I also noticed the SMD fuses near the PCI-E slot are blown.
    So 2 questions:
    1) Should I expect any other damaged component since the PSU and the computer start again?
    2) Can someone tell me what are these two fuses details circled in the picture?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: GTS 250 GPU short circuit
    Since the shorted MOSFET was a high-side MOSFET, the GPU can be dead (sending 12V to GPU VCore). You can also check the resistance between the GPU VCore inductors and ground to know if there's a shorted low-side MOSFET or shorted GPU. It is expected to be low, but probably not lower than 2ohms.
    Also when replacing a MOSFET it's advised to replace the PWM controller as well, and match the batch numbers of all the high side MOSFETs (or low-side).
    The fuses are between the 12V power rail coming from the PCIe port and the input of a buck converter. Not sure what they are though, but at least several amps. (PCIe port can give 75W on the 12V rail)
    • Sraros
      • Jan 2017
      • 223
      • Greece
      Thanks for having a look. In the photo I uploaded I have circled in red the MOSFET I removed and tested the GPU to see if the PC will open. The one in green circle I just pointed out so not to bother. It's the original MOSFET I thought it was shorted but then I badly soldered it since I am going to replace all of them either way. I guess this is the Vcore section or high-side as you mention?
      The fuses I found are 5-6A pretty much makes sense what you said about 75W delivery.
      Now.. what I would appreciate from you to do is draw on my pic where the PWM is located in order to change that too.. and where I need to measure the resistance between the GPU VCore inductors and ground as you said. If it's the cubes next to the MOSFETS marked as R80, resistance is 1,2 Ohm
      Does this mean I might got away with a short on the low side?
      This is my first GPU attempt to fix
      • OOF DIO
        ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
        by OOF DIO
        (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
        (Had 3 problems, now just 1)
        I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
        I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
        I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
        04-19-2025, 05:03 PM
      • Nooy
        VGA MOSfet permanently shorted and loss of MOSfet pad
        by Nooy
        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
        02-14-2024, 02:26 AM
      • Tarot Superstars
        Short Circuit tester
        by Tarot Superstars
        Hello.
        I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
        The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
        Link
        The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
        https://www.youtube.com/watch?v=0eixDdCpiO4
        My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
        09-25-2023, 09:11 AM
      • fab13
        Nintendo Switch lite charging chip heats up and does not short circuit
        by fab13
        Hello everyone
        Small technical problem on a Nintendo Switch lite
        Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
        After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
        When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
        Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
        09-16-2023, 04:59 AM
      • ryogadan78
        Xbox Series X
        by ryogadan78
        Good morning guys,
        I am resuming an old service on an Xbox X Series that I really want to repair. I summarise what has been done because I can't find my previous post.
        The Xbox initially did not turn on, no LED, no beep. Found short circuit on the 12V connector on the bottom board. Injecting 1.5V on the positive side of one of the shorted capacitors to find with the thermal camera which capacitor was shorted, no gave me useful information. The board draws 2.80A (1.5V), but from the thermal camera images I don't see any component getting hot.
        I removed the coils one by...
        11-16-2024, 04:46 AM
