Need a professional help! Acer E5 does not Power on!
Re: Need a professional help! Acer E5 does not Power on!
PT3661-BB = 661 Prolific
EM-6781-T3 = ??? AKM
AH180N = K9 Diodes
APX9131 = X31X Anpec
APX9132 = X32X Anpec
MH248BESO = 248x MST/magnesensor
OCH1691WAD = 251x ???
AH9249NTR-G1 = GJ9 Diodes or BCD
mostly when i'm seeking component for quanta I will also looking at quanta's donor board and same brand. after reading lots datasheet and compare HD image board, seem they were all use same component for any brand and manufacturer.
Quanta donor board with label on PCB MR1 or HE1
Wistron donor board LID1
Compal / inventec donor board Ux/Uxx/UxxxLast edited by on/off; 12-09-2018, 07:27 AM.Comment
Part | Marking Code | Vendor
AH180N = K9 Diodes
I check all the quanta motherboards I have...Comment
Thanks you Guys, your posts helped me with the same problem... My troubles was with bad keyboard, but i was not able to start notebook manualy by shorting of last two pins of keyboard connector. Dead, MR1 was the reason of my troubles... for now i have solved it by shorting MR1, but i will try to order new sensor. Thanks.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by usbdeviceHi all
There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
https://www.badcaps.net/forum/showthread.php?t=50657
https://www.badcaps.net/forum/showthread.php?t=40512
The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
It's my dad's old monitor. He...-
- Loading...
