The best adhesive on hot heatsinks?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear forum members,
    In laptops, sometimes we need to glue something such as an insulator sheet on CPU heatsink. Or sometimes we need to glue a rubber heatsink on PCH.
    As these heatsinks may reach 50'C to 90'C, it is possible that the adhesive get loose so that the heatsink moves on PCH.
    Silicon thermal paste is loose too. So it is not suitable for gluing heatsink on PCH. and there is no screw to fix the heatsink on PCH.
    what kind of adhesive suites this job that transfers heat properly and does not get loose under 100'C and less?
    thanks
  • petehall347
    • Jan 2015
    • 4440
    Re: The best adhesive on hot heatsinks?
    try thermal adhesive .
    lots to choose from .
    https://uk.rs-online.com/web/c/adhes...mal-adhesives/
      • 21889
      Sekisui 5760 is a good option .
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        Thanks for the replies, petehall347 and SMDFlea. I will go to a local electronics shop tomorrow to see which one of these adhesives are available here.
          • 31248
          Iran still has local parts shops?
          most in western europe have gone out of business - i think the u.s. is the same.
          there are a few in Russia, but that's a huge country so a few shops is still minimal.
          • harp
            Metod for removing glued heatsink from fragile component
            by harp
            I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
            06-23-2025, 02:01 PM
          • Katz993
            iMac Display Replacement Adhesive
            by Katz993
            TL;DR: Looking for as-close-to-genuine as possible iMac Thin Panel (2012-2019) Adhesive.
            Long Rant: I run a tech shop that has a specialty in Macs. We've been doing upgrades and repairs on the thin panel iMacs as long as they've been out, and I've always had the issue of being unable to get something close to the OEM Adhesive for the Display Assembly, i.e. a 'two-part' adhesive, extremely thin but durable and can be cut easily with a thin wheel cutter. My replacement adhesive has always been essentially standard thin adhesive. For a long time, the biggest annoyance with this was having...
            03-15-2022, 10:31 AM
          • Ven
            Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
            by Ven
            I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
            The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
            I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
            If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
            07-08-2024, 09:32 AM
          • mitsu2k
            The Real Dangers of conductive glue.
            by mitsu2k
            I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
            Here is an experience I...
            04-16-2023, 06:29 PM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
