Hp2530p charging light
  • akande
    • Dec 2017
    • 278
    • Nigeria
    I have hp 2530p that is not coming up, it only blink blue light when power adaptor connected attached is schmatics for help pls
    • 20807
    Re: Hp2530p charging light
    What basic tests have you done so far ,do you have 19V at main input mosfet ,3VALW ,5VALW , 3V at power button .
    • akande
      • Dec 2017
      • 278
      • Nigeria
      yes there is 19v and 3v at power botton
        • 20807
        5valw , do you have the schematic .
        • akande
          • Dec 2017
          • 278
          • Nigeria
          this is it bro
            • 20807
            Check voltage on PU5 pin 21 +5VALWP
            • akande
              • Dec 2017
              • 278
              • Nigeria
              its 0v at pin 21 of pu5
                • 20807
                Change PU5
                • akande
                  • Dec 2017
                  • 278
                  • Nigeria
                  Change PU5
                  thanks bro , but from which other mother board can get a compatible type plz
                    • 20807
                    Remove PU5 (MAX8734EEI) and check if pin 21 is short to gnd or not before replacing. I can`t find a compatible IC , the sony MBX-149 has the IC if you have a donor board.
                    • akande
                      • Dec 2017
                      • 278
                      • Nigeria
                      thank bro after removing pu5 i founf out pin 21 is short to groung . what next bro?
                        • 20807
                        You need to find where the short is, inject voltage on the +5VALWP line ,and see what gets hot .
                        • akande
                          • Dec 2017
                          • 278
                          • Nigeria
                          After injecting voltage , pq11 found shorted. I change it and discover pq10 and pq9 also become very hot 'change them also. Now put pin21 of put short gone but condition of pc remains the same. Charge light keep blinking when power cord connected and 19v still miss at pin 21 of pu5 despite changing pu21 , what next bro
                          • akande
                            • Dec 2017
                            • 278
                            • Nigeria
                            Pu5 I mean
                              • 20807
                              Pin 21 should be 5V ,not 19. If you don`t have 5V change PU5 .
                              EDIT: attatched MAX8734 datasheet.
                              • Elecfronicsssss
                                DA0NJJMBAG0 charging light blinks
                                by Elecfronicsssss
                                Laptop motherboard DA0NJJMBAG0
                                PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                GUIDE ME WITH THE PROBLEM..
                                SUMMARY-
                                1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                05-12-2025, 02:32 AM
                              • esqmooo
                                HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                by esqmooo
                                Hello everyone.
                                This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                03-11-2025, 03:57 PM
                              • serious_electron
                                Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                by serious_electron
                                Hello Everyone!
                                I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                06-28-2025, 02:57 PM
                              • esqmooo
                                HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                by esqmooo
                                I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                03-07-2025, 05:55 AM
                              • flat-earther
                                ASUS X54H laptop thinks it's always charging even with charger unplugged
                                by flat-earther
                                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                Windows also shows ''Plugged in'' when charger is not connected.
                                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                If I let battery run out and say it has 3% Windows will...
                                06-24-2025, 09:32 AM
