Hp2530p charging light
  • akande
    • Dec 2017
    • 278
    • Nigeria
    I have hp 2530p that is not coming up, it only blink blue light when power adaptor connected attached is schmatics for help pls
    • 21922
    Re: Hp2530p charging light
    What basic tests have you done so far ,do you have 19V at main input mosfet ,3VALW ,5VALW , 3V at power button .
    • akande
      • Dec 2017
      • 278
      • Nigeria
      yes there is 19v and 3v at power botton
        • 21922
        5valw , do you have the schematic .
        • akande
          • Dec 2017
          • 278
          • Nigeria
          this is it bro
            • 21922
            Check voltage on PU5 pin 21 +5VALWP
            • akande
              • Dec 2017
              • 278
              • Nigeria
              its 0v at pin 21 of pu5
                • 21922
                Change PU5
                • akande
                  • Dec 2017
                  • 278
                  • Nigeria
                  Change PU5
                  thanks bro , but from which other mother board can get a compatible type plz
                    • 21922
                    Remove PU5 (MAX8734EEI) and check if pin 21 is short to gnd or not before replacing. I can`t find a compatible IC , the sony MBX-149 has the IC if you have a donor board.
                    • akande
                      • Dec 2017
                      • 278
                      • Nigeria
                      thank bro after removing pu5 i founf out pin 21 is short to groung . what next bro?
                        • 21922
                        You need to find where the short is, inject voltage on the +5VALWP line ,and see what gets hot .
                        • akande
                          • Dec 2017
                          • 278
                          • Nigeria
                          After injecting voltage , pq11 found shorted. I change it and discover pq10 and pq9 also become very hot 'change them also. Now put pin21 of put short gone but condition of pc remains the same. Charge light keep blinking when power cord connected and 19v still miss at pin 21 of pu5 despite changing pu21 , what next bro
                          • akande
                            • Dec 2017
                            • 278
                            • Nigeria
                            Pu5 I mean
                              • 21922
                              Pin 21 should be 5V ,not 19. If you don`t have 5V change PU5 .
                              EDIT: attatched MAX8734 datasheet.
