BQ24738 Voltage Readings
  • orientalsniper
    • Apr 2013
    • 459
    Hello, can anyone tell me if these are correct voltage readings (with battery connected) for IC BQ24738 (BQ738) ?
    19.31
    19.33
    19.30
    25.50
    3.3
    2.6
    0.3
    3.2
    3.2
    0.7
    16.73
    16.75
    16.78
    0
    0.48
    6.05
    22.24
    21.46
    16.88
    18.86
    Problem with motherboard (LA-A993P) is it's not charging when powered on, can only charge battery if it's powered off. Already replaced IC, flashed bios and reprogrammed KBC.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: BQ24738 Voltage Readings
    pin15 and pin18 does not seem OK. you should measure BQ24738 both when the laptop is powered on and powered off. upload the mainboard's schematics file if you have it.
    • orientalsniper
      • Apr 2013
      • 459
      Powered on, but not charging:
      15.56
      15.52
      0.2
      0.2
      3.3
      2.6
      0
      3.2
      3.2
      0.7
      21.6
      15.23
      15.22
      0
      0
      6.05
      14.97
      15.20
      15.20
      19.31
      There's no schematic for this motherboard, but I extracted a page from a different motherboard with same charging IC.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        I think the measurements in Post3 are done when the AC adapter was disconnected from the laptop. If so, repeat it with the AC adapter connected. If the AC adapter is disconnected, you cannot find a clue to solve the problem.
        • orientalsniper
          • Apr 2013
          • 459
          Nooo, adapter was plugged!
          • laztop
            • Dec 2012
            • indonesia
            MOSFET BATT short
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              that may be right. when the AC adapter and the battery are removed, check the Mosfets connected to BQ24738 for being shorted.
              • ablbilgi
                • Feb 2017
                • 6
                • turkiye
                laztop yes gpu mosfet short for me. thanks
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  you can use the datasheet of the bq24735 is similar.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • Instafixx
                    Macbook A2179 820-01958
                    by Instafixx
                    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                    I checked the Power Sequences below and found this -
                    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                    05-20-2023, 05:19 AM
                  • Fernon@Repair
                    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                    by Fernon@Repair
                    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                    VCCIO voltage ok
                    VCCSA Voltage OK
                    VCCPLL Voltage OK
                    Ram Voltage ok
                    RamVTT OK
                    VPP 2.5 OK
                    But No Core Voltage
                    and i want to this vrm ic datasheet or pinout (ISL69269)
                    anyone have this ic pinout voltages?...
                    06-25-2025, 07:19 AM
                  • electron_jj
                    Panasonic TH-L42D25A checking the PSU output voltage
                    by electron_jj
                    Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                    I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                    08-29-2021, 08:13 AM
                    Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                    I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                    The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                    Now...
                    06-09-2024, 10:57 AM
