HP G42 458TU Battery Drain
  • sabareeshchambayil
    • Jan 2016
    • India
    My hp g42 458tu laptop is always in powered condition( i mean its shutting own ,but dvd drive harddisk etc are working) . If I kept battery in laptop full charged it will be drained with in 1 day and its a new battery.
    At first I thought it would be related to windows 10 ,so I checked removing harddisk and same thing happened.
    So I checked by removing battery ,harddisk and plugged adapter and pressed DVD drive and it's working without pressing power button, and display color is changing to dark and white(like flikering without back light)
    I am ready to repair this myself (I mean chip level)
    I have all the accessories and tools for repair and I disassembled laptop but no components seem to be visibly damaged.
    i Dont know where to start.
    Board ID is DAAX1JMB8C0 REV:C
    i got the schematic for this model by a google search
    Any help will be greatly appreciated.
    • 20918
    Re: HP G42 458TU Battery Drain
    Did you calibrate the new battery. Heres a hp support doc https://support.hp.com/gb-en/document/c04700771
    Do you still have the old battery.Check to see if its part of the battery recall
    https://h30686.www3.hp.com/?lang=en-GB
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      So when you plug the AC adapter in, the laptop turns on automatically and the screen has display. and the laptop cannot shut down completely. it that right?
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • gboone
        820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
        by gboone
        Hi, I was given this laptop by my uncle who said:
        • It would occasionally shutdown if not plugged in
        • battery had been replaced
        • touchbar would "strobe"
        I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
        After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
        BUT
        When powered off, it would at some point have a...
        01-27-2025, 09:12 AM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
