Acer E5-571G Black Screen (a5wah la-b991p)
  • robgerr
    • Apr 2012
    • 70
    • Italy
    Good evening friends of the forum. This laptop has the following problem: it turns on but I get a black screen. Think of a dedicated gpu problem (n15-v-gw-s-a2) Replaced video card but the defect remains. I tried Changing ram, reprogram bios, but nothing. I noticed that the coil pl1203, pl1204 and pl 802 are heating a lot. On pl1203, pl1204 I find the voltage of 1.01V and on pl802 I find 1.80v on one side and on the other I get 0.40v. I suspect this is the integrated graphics in the chipset but I wanted your opinion
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer E5-571G Black Screen (a5wah la-b991p)
    Though i dont have the schematics but i think PL1203/04 is for vcc core and PL802 is GFX core. So the voltage seems to be ok. Are you getting PLT RST??
    • robgerr
      • Apr 2012
      • 70
      • Italy
      I upload the schematic, https://anonfile.com/k7cfjbkebe/comp...lab991pr10_pdf
      • robgerr
        • Apr 2012
        • 70
        • Italy
        measured plt_rst on pin 13 of kbc and result 3,30v
        • robgerr
          • Apr 2012
          • 70
          • Italy
          Any help please...
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            You need to measure PU801 voltage on all pins. Pl1203/4 are expected to heat-so nothing to worry there. Since you are getting PLT_Rst means almost all power up seqeunce reuirement are fulfilled.
            • robgerr
              • Apr 2012
              • 70
              • Italy
              pu801:
              pin 1 1,04v
              pin 2 1,04v
              pin 3 0v
              pin 4 1,04v
              pin 5 1,67v
              pin 6 2,00v
              pin 7 1,74v
              pin 8 0v
              pin 9 1,80v
              pin 10 1,80v
              pin 11 0v
              pin 12 5,04v
              pin 13 7,57v
              pin14 8,14v
              pin 15 8,21v
              pin 16 4,40v
              pin17 0v
              pin18 1,04v
              pin 19 1,04v
              pin 20 1,04
              • robgerr
                • Apr 2012
                • 70
                • Italy
                is correct value?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Originally posted by robgerr
                  is correct value?
                  No, the values doesnt seems to be correct. VR oN should be 3.3v . Voltage on pin121 of KBC9022??
                  • robgerr
                    • Apr 2012
                    • 70
                    • Italy
                    pin 121 3,3v
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      So kbc seems to give VR_ON output correctly but still you are having 1.04 at pin1 of PU801. You need to check resistors, caps connected to PU801 and match them with schematic. Is PU801 soldered properly? Any corrosion, missing tracks?? If everything seems good, you can try replacing PU801.
                      • robgerr
                        • Apr 2012
                        • 70
                        • Italy
                        Good afternoon friends of the forum. I replaced PU801 but the defect remains. on pin 1 of pu801 I find 1.05V. Other suggestion?
                        • teknikbursa
                          • Sep 2014
                          • 64
                          • turkey
                          pls check I/O for liquid damage is common problem on this board
                          • jasko_jacker
                            • Oct 2014
                            • 1137
                            • italy
                            Unfortunately, in these cases, when attempts are made; problems may increase.
                            Personally, I would try to bring the situation back to its initial state,
                            change the bios with the original, check that there are all the correct voltages and try to reprogram the EC.
                            • lazybigyan
                              • Mar 2017
                              • 78
                              • Nepal
                              Is it possible to convert UMA removing by PL1201 or not? Do you have any idea to convert discrete to uma by any other method? Thanks in advance.
                              • Sametbey
                                • Jan 2021
                                • 229
                                • Turkey
                                can you try? " Acer E5-571G A5WAH LA-B991P Rev 1.0
                                When the solder on the PJ1002 jumper feeding the RAMs on the left side of the GPU is cleaned and the U40 mosfet located on the right side of the GPU is removed, the Nvidia graphics card is disabled. "
                                I'm not happy to be so strong. because it's not humanly
                                • lapfix
                                  • Mar 2020
                                  • 2720
                                  • my workshop
                                  Hello friends ...got the same motherboard with same issue .
                                  When power on i got a backlight but no picture , i have picture at external .
                                  All the voltages are present , plt_rst too , Vr_on too...but at pin 1 of PU801 got 1.04v.
                                  I also do a uma enable as Post18 mention but same isse.
                                  At lvds connector all voltages are present expect : INVTPWM / DISPOFF# / EDP_HPD = 0v.
                                  Change screen same too
                                  What i must check too !
                                  Thank you
                                  • lapfix
                                    • Mar 2020
                                    • 2720
                                    • my workshop
                                    Update :
                                    pu801:
                                    pin 1 = VR_ON = 1,052v
                                    pin 2 = PGOOD = 1,052v
                                    pin 3 0v
                                    pin 4 1,052v
                                    pin 5 1,8v
                                    pin 6 2,00v
                                    VR_ON is coming from U1L (CPU) there's a resistor (Not populated) R167 = 1.05v at 2 pads.
                                    The VGATE_3V is coming from U17 (Not populated )
                                    U17 pads
                                    pin 2 = 1.05v
                                    pin 5 = 1.05V
                                    pin 4 = VGATE_3V = 0v
                                    VGATE source !
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Pu801,pin1 voltage at 1.05v is correct. Have u flashed bios?? What about U43?~
                                      • lapfix
                                        • Mar 2020
                                        • 2720
                                        • my workshop
                                        Thank you my friend.
                                        Since i have a picture at external so i think no need to flash bios !
                                        But i do a clean me and flash new virgin dump , same issue , only external and a backlight at internal as i mention before.
                                        U43 not populated :
                                        1 = not stable = 1.7v or 0.043v or 1.8 with fluctuation at 1 or 0 v
                                        2 = 3v
                                        3 = gnd
                                        4 = 3.2v
                                        5 = 3.3v
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • ipatch
                                          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                                          by ipatch
                                          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                                          08-24-2024, 02:36 PM
