Good evening friends of the forum. This laptop has the following problem: it turns on but I get a black screen. Think of a dedicated gpu problem (n15-v-gw-s-a2) Replaced video card but the defect remains. I tried Changing ram, reprogram bios, but nothing. I noticed that the coil pl1203, pl1204 and pl 802 are heating a lot. On pl1203, pl1204 I find the voltage of 1.01V and on pl802 I find 1.80v on one side and on the other I get 0.40v. I suspect this is the integrated graphics in the chipset but I wanted your opinion
Acer E5-571G Black Screen (a5wah la-b991p)
Re: Acer E5-571G Black Screen (a5wah la-b991p)
Though i dont have the schematics but i think PL1203/04 is for vcc core and PL802 is GFX core. So the voltage seems to be ok. Are you getting PLT RST?? -
I upload the schematic, https://anonfile.com/k7cfjbkebe/comp...lab991pr10_pdfComment
You need to measure PU801 voltage on all pins. Pl1203/4 are expected to heat-so nothing to worry there. Since you are getting PLT_Rst means almost all power up seqeunce reuirement are fulfilled.Comment
pu801:
pin 1 1,04v
pin 2 1,04v
pin 3 0v
pin 4 1,04v
pin 5 1,67v
pin 6 2,00v
pin 7 1,74v
pin 8 0v
pin 9 1,80v
pin 10 1,80v
pin 11 0v
pin 12 5,04v
pin 13 7,57v
pin14 8,14v
pin 15 8,21v
pin 16 4,40v
pin17 0v
pin18 1,04v
pin 19 1,04v
pin 20 1,04Comment
So kbc seems to give VR_ON output correctly but still you are having 1.04 at pin1 of PU801. You need to check resistors, caps connected to PU801 and match them with schematic. Is PU801 soldered properly? Any corrosion, missing tracks?? If everything seems good, you can try replacing PU801.Comment
Unfortunately, in these cases, when attempts are made; problems may increase.
Personally, I would try to bring the situation back to its initial state,
change the bios with the original, check that there are all the correct voltages and try to reprogram the EC.Comment
Is it possible to convert UMA removing by PL1201 or not? Do you have any idea to convert discrete to uma by any other method? Thanks in advance.Comment
can you try? " Acer E5-571G A5WAH LA-B991P Rev 1.0
When the solder on the PJ1002 jumper feeding the RAMs on the left side of the GPU is cleaned and the U40 mosfet located on the right side of the GPU is removed, the Nvidia graphics card is disabled. "I'm not happy to be so strong. because it's not humanlyComment
Hello friends ...got the same motherboard with same issue .
When power on i got a backlight but no picture , i have picture at external .
All the voltages are present , plt_rst too , Vr_on too...but at pin 1 of PU801 got 1.04v.
I also do a uma enable as Post18 mention but same isse.
At lvds connector all voltages are present expect : INVTPWM / DISPOFF# / EDP_HPD = 0v.
Change screen same too
What i must check too !
Thank youComment
Update :
pu801:
pin 1 = VR_ON = 1,052v
pin 2 = PGOOD = 1,052v
pin 3 0v
pin 4 1,052v
pin 5 1,8v
pin 6 2,00v
VR_ON is coming from U1L (CPU) there's a resistor (Not populated) R167 = 1.05v at 2 pads.
The VGATE_3V is coming from U17 (Not populated )
U17 pads
pin 2 = 1.05v
pin 5 = 1.05V
pin 4 = VGATE_3V = 0v
VGATE source !Last edited by lapfix; 03-02-2022, 06:54 AM.Comment
Pu801,pin1 voltage at 1.05v is correct. Have u flashed bios?? What about U43?~Comment
Thank you my friend.
Since i have a picture at external so i think no need to flash bios !
But i do a clean me and flash new virgin dump , same issue , only external and a backlight at internal as i mention before.
U43 not populated :
1 = not stable = 1.7v or 0.043v or 1.8 with fluctuation at 1 or 0 v
2 = 3v
3 = gnd
4 = 3.2v
5 = 3.3vLast edited by lapfix; 03-03-2022, 03:20 AM.Comment
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo - Loading...
