hp 8460 charging problem
  • hazim
    • Mar 2016
    • 62
    • egypt
    i have 2 lap hp 8460
    and one hp 8470p
    problem battery not charging at all
    replace batt and bq736 charging ic
    on charger coil 1.0 volt
    lap turn on and work but batt not charg
    i need your help
  • dimah77
    • Sep 2016
    • 147
    • ALGERIA
    Re: hp 8460 charging problem
    Same problem with hp 8470p :
    Laptop work perfectly on battery and on charger separately, but when both plugged, it not detect charger at all
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Originally posted by dimah77
      Same problem with hp 8460p :
      your discharge mosfet is likely bad. try replacing it.
      • dimah77
        • Sep 2016
        • 147
        • ALGERIA
        Can u Help me with schematics please ?
        MB : 6050A2466401-MB-A04
        • Conste
          • Oct 2018
          • 235
          I have a similar unit here which works fine, I can measure some points, if you want
          • dimah77
            • Sep 2016
            • 147
            • ALGERIA
            Originally posted by conste
            i have a similar unit here which works fine, i can measure some points, if you want
            thanx !!
            • Conste
              • Oct 2018
              • 235
              Can you make a photo of the area? Do I have to disassemble the unit?
              • dimah77
                • Sep 2016
                • 147
                • ALGERIA
                Here is :
                • Conste
                  • Oct 2018
                  • 235
                  Puh I had to disassemble the whole unit right? ��
                  • dimah77
                    • Sep 2016
                    • 147
                    • ALGERIA
                    Sorry
                    • on/off
                      • Oct 2016
                      • 333
                      • Indonesia
                      Try to search first
                      Check this link:
                      https://www.badcaps.net/forum/showthread.php?t=60286
                      • dimah77
                        • Sep 2016
                        • 147
                        • ALGERIA
                        Originally posted by on/off
                        Try to search first
                        Check this link:
                        Thanx friend, I see this post, but it's too old and not solved yet, can u give some help please ?
                        • Conste
                          • Oct 2018
                          • 235
                          Do you still need the voltages?
                          Really hard to disassemble the unit...
                          • on/off
                            • Oct 2016
                            • 333
                            • Indonesia
                            Sorry, I didn't open your pics. (post #6 and #8, attached thumbnails)
                            I think ADP_EN should be 3.3V. when this Q6009 going high on gate at pin2 R6015 will grounded.This purpose to make R6015 and R6017 be resistor divider, since Q6010 is P-Channel Mosfet.
                            Does your measurement only on adapter or both adapter and battery?
                            I think you should check if you have any mosfets short (between Drain-Source-Gate pin out), why is Q6010 going protect mode (on gate have 19V).
                            Also ADP_DET should be 3.3V as feedback report to KBC chips that adapter present and pass verifying have correct voltage.
                            • bembeno
                              • Feb 2016
                              • 307
                              • egypt
                              HP 8470p work good from adapter only and work good from battarey but when connect adapter and battarey its work good but not charging i tried another adapter and another battarey but its the same
                              • mon2
                                • Dec 2019
                                • 14140
                                Review the sticky above on charging circuits by @Piernov.
                                check the first 2 DCin mosfets. Measure their voltage to ground for source / gate / drain pins. Post each measurement.
                                • Scoff
                                  HP Probook 470 G4 - Power and Charging Problem
                                  by Scoff
                                  Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                  Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                  07-03-2023, 09:28 AM
                                • ahmarzo
                                  Hp laptop charging problem
                                  by ahmarzo
                                  Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
                                  Charging ic is bq737 with voltages on pin no
                                  1&2 -19v
                                  34&5 -0v
                                  6 -2.56 v
                                  7- 0v
                                  8&9 -3.15v
                                  10 -0v
                                  11 -0.18v
                                  12 & 13 -13v
                                  14&15 -0v
                                  16 -6v
                                  17;18&19 -13v
                                  20 - 19v
                                  Voltages on battery connector are
                                  1&2. -13v
                                  3&4 -3.14 v
                                  5&6 -0v
                                  8&9 are ground...
                                  03-20-2025, 05:13 AM
                                • roman728
                                  Lenovo E15 / NM-C421 Charging Problem
                                  by roman728
                                  Hello guys,
                                  I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
                                  02-20-2024, 03:40 AM
                                • kity92
                                  Edifier x3 Earbuds Blue Light Problem (Charging Problem)
                                  by kity92
                                  I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
                                  Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
                                  01-13-2022, 01:49 PM
                                • delphi_firebird
                                  Toshiba Qosmio X755 Charging problem
                                  by delphi_firebird
                                  Hello Guys,
                                  I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
                                  - When battery is unplugged i works without any problem.
                                  - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
                                  - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
                                  Can you help me diagnose the problem? I have attached...
                                  10-16-2023, 03:04 AM
