Lesia phone "supported API 3" Bricked
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I'm not a gadget guy by any means and only know some very basics about phones and tablets, so I'm asking for a bit of help here. I've got this phone called Lesia Note X, some sort of knock-off, doesn't really matter since it may apply to other phones of this kind as well, which gets stuck on the logo screen. If I try to hold the power button and the volume up key, instead of the recovery menu showing up like with other phones, I get "Supported API: 3" in the bottom-left corner and that's it. To make matter worse, at no point is this guy being detected by the computer. When I plug the cable in, I DO get a "hardware attached" notification, but then before anything even shows up, I get a "disconnected" sound, so no devices show up in device manager, not even an unknown one, so this is bricked to hell...
    There's very little resources on this "API: 3" issue and even less about this phone. From what I've seen, it appears to be similar to a ZTE phone, but couldn't find any resources on unbricking it. If I could at least get it to stay connected, maybe we can work from there, but it doesn't. It's not a cable issue, as the interval between the connection and the disconnection is always the same and charging works fine... so if anyone's got any ideas, they would be greatly appreciated. Thank you.
    Wattevah...
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Lesia phone "supported API 3" Bricked
    From the info I found on the internet it looks like this uses a Mediatek MT6580 chipset. You will need SP Flash Tool for MT6580, MTK USB VCOM drivers and appropriate firmware. To flash the phone, you need to disconnect the battery, plug in USB cable, then connect the battery. Then you should be able to see it in Device Manager and install the drivers so the phone will get recognized by SP Flash Tool.
    Obtaining the right firmware is likely to be the trickiest part.
    A working TV? How boring!
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Haven't been able to get it to stay connected in any shape or form and that includes removing the battery. I shall push on however. So you just have the cable ready and plugged in and then connect the battery ? I couldn't get it to do anything different that way sadly - it just begins charging and does the connect-disconnect routine again....could be a hardware issue as well ? :| EMMC or something like that ? Again, I don't know much about phones, just generics....
      Yes, obtaining a firmware for it is imposibilimibidadido....unless it can accept one from a different device...
      Wattevah...
      • petehall347
        • Jan 2015
        • 4446
        • United Kingdom
        is you computer running linux ?
          • 31260
          go look at gsm-forum.
          http://forum.gsmhosting.com/vbb/index.php
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            No, Windows, but if Linux knows of any tricks that could help in the situation at had, I could very well setup a separate machine or hard drive for it.
            Wattevah...
              • 21986
              Have you installed any drivers yet. https://forum.xda-developers.com/ele...32-64-t3267033
              EDIT: heres another driver installer http://community.umidigi.com/thread-2962-1-1.html
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                So if I understand correctly, the driver will allow the phone to connect even in this "dead" state ? Worth a try I suppose, though it doesn't show up AT ALL, not even as an unknown device, but perhaps that's the whole purpose of those drivers you linked to...
                Wattevah...
                  • 21986
                  Maybe. To quote from the xda link : "Now, when you will connect your turned off MTK device to the Windows 10 computer by USB, the device will be recognized either trough a MediaTek Preloader USB VCOM Port interface or as a MTK USB port if it is bricked or it has bad/corrupt firmware.The SP Flash Tool will be able to transfer the firmware to your device trough this interfaces. Make sure you connect the device after you press the Download button in SP Flash Tool, as the communication interface will only be alive for 2 seconds if no data is being sent."
                  If the phone is recognised you`ll still need to find a firmware img as Th3_uN1Qu3 said at post #2 .
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Yeah, that's what I made out from that post myself, but finding a firmware is going to be tough sh!t....
                    Wattevah...
                    • petehall347
                      • Jan 2015
                      • 4446
                      • United Kingdom
                      with android being more like linux than windows is i would think you will be better using a linux machine . there is info on this problem on stack overflow website .. will see if i can find it again . . https://stackoverflow.com/questions/...api-level-mean
                      then there is plenty more on google .. https://www.google.co.uk/search?q=Su...hrome&ie=UTF-8
                      • petehall347
                        • Jan 2015
                        • 4446
                        • United Kingdom
                        plug it into a linux machine .. open a terminal CTRL ALT T . then type in lsusb into terminal hit enter . it will show you if device is being recognised or not .
                          • 31260
                          i think you mean lsusb
                          • petehall347
                            • Jan 2015
                            • 4446
                            • United Kingdom
                            yes indeed i did . now corrected
                              • 21986
                              Can you tell us what the board ID number is .
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                Would that be written somewhere on it ? Could it be THIS ? Sorry, it's a little blurry....it was early in the morning
                                I also grabbed those driver and installed them. Although they made no difference in the way the phone is detected (that is, it DOESN'T get detected), what I THINK it's supposed to happen is after you've got the correct "scatter" file loaded in SPFlash tool and hit "download", you THEN connect the phone and in that brief moment when it manages to talk to the PC, SPFLash "catches" it and begins doing its thing before it disconnects again.....that's the only way I'd see this thing working, because it doesn't appear as a VCOM device or anything like that at any point in device manager...
                                Wattevah...
                                  • 21986
                                  There`s no info online for that board ID. I think your only option now is to contact lesia and ask them for the firmware, they might send you a download link.
                                  http://www.lesia.hk/contact.php
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    I have always flashed these devices under Windows, the Chinese companies only supply Windows software. MTK chipsets have the USB download mode stack in the bootloader, so it's impossible to permanently brick them via software - with the right firmware update, the device should start.
                                    But if you do not have the drivers installed then it will toggle out of that mode if the firmware asks it to (reset). Try installing the USB VCOM drivers and you should get the popup about installing drivers for that device, even if it disappears in the meantime, next time it is connected the driver will pick it up.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      I did install the drivers, but no difference like I said, despite the system going "duh-dum" when you plug it in. It then goes "dum-duh" again and there's no message whatsoever - then it just begins charging and displaying the battery animation. Same goes if I press and hold UP and power - it eventually displays the API 3 message, accompanied by the same connection attempt. I'm under win 7 though I doubt it's relevant.
                                      Meh, nothing to lose. Sent the chaps an email describing my issue. What's ironic here is that chinese companies seem to have BETTER "support" (if we can even call it that) and against all expectations they DO reply and even provide whatever's required. At least that's what others have described in other situations when pursuing these avenues that seem totally ridiculous.
                                      I personally noticed this trend on Aliexpress: no matter how cheap a product is, the sellers will do everything they can to satisfy your requests even if you're not guaranteed you're going to buy it. Off topic: I needed some parts to build an automated curtain drawing machine (long story - another time ) and I was interested in the weight of a particular part. It wasn't mentioned in the product page, so I contacted the seller and asked them what it weighed. They said they didn't have the part readily on hand to weigh it and they'd have to ask about it at their warehouse...yeah, sure, I though, like THAT'S ever going to happen...why would they bother for 50 cents a piece ? It's basically a very polite "fuck off"....1 day later, I get a message from the chap with a photo of the part placed on a scale displaying the grams and saying "here you go".....they actually went out of their way to weigh that thing just for me and take a picture of it...hats off to you for your extreme (if not ridiculous !) sense of responsibility and devotion to your POTENTIAL customers ! China man ! You don't mess with China !
                                      Wattevah...
                                        • 21986
                                        "Make sure you connect the device after you press the Download button in SP Flash Tool, as the communication interface will only be alive for 2 seconds if no data is being sent."
                                        It seems that without the firmware to send to the phone the connection is closed.
                                        • SluggerB
                                          Help with trying to fix phone that is not charging (Pics inside)
                                          by SluggerB
                                          I have two TCL A30 phones.
                                          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                          New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                          08-12-2024, 08:11 AM
                                        • keeney123
                                          new OS on a Sonim XP5s phone
                                          by keeney123
                                          To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                                          I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                                          05-13-2022, 07:19 PM
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • pwingman
                                          HP ZBook Firefly 14(G8) (PASS)(UNLOCK)
                                          by pwingman
                                          I forgot the password of the admin settings do I need to dump the original bios first?
                                          Code:
                                          System Information
                                              Manufacturer: HP
                                              Product Name: HP ZBook Firefly 14 inch G8 Mobile Workstation PC
                                              Version:
                                              Serial Number: 5CG1070BLR
                                              UUID: d996a728-d393-4bfb-a592-ac1f5fda2e7e
                                              Wake-up Type: Power Switch
                                              SKU Number: 2C9Q1EA#ABH
                                              Family: 103C_5336AN HP ZBook
                                          BIOS Information
                                              Vendor: HP
                                              Version: T76 Ver. 01.01.32
                                              Release Date: 03/26/2021
                                          09-25-2024, 02:41 AM
                                        • mikey5791
                                          Help with Samsung Galaxy J7 Prime phone
                                          by mikey5791
                                          Got this smart phone free from a guy who dropped it hard until the lcd display cracked with no seen display.
                                          Opened it and found the display ribbon cable partly damaged. I charged the phone full in 2 hours time, the led red light turns to green indicate full charge.
                                          Then i use a usb cable connect the phone to laptop but it only showed as media player with firmware version. Too bad there is no option to check folder.
                                          Does anyone know any method to check if the phone is working good? Looking forward for any advice and help possible.
                                          If tested the...
                                          09-15-2021, 07:54 PM
