Help me remove shorting Compal LA- 5752p
  • IamPritesh
    • Aug 2017
    • 356
    • India
    I had this laptop which had flickering screen but everything else was working fine.
    I tried a new lvds cable and that is when things got even worse. now the laptop does not start at all.
    If I remove the cpu, then it try to start though with leds glowing , fan moving and then shutting down obviously.
    If I put the cpu back and plug in the ac adapter, i can hear a tick tick sound coming from the cpu ..
    Upon checking I can see shorting in the 1.05VS line. PJ1 has shorting on the +1.05VS side.
    I have DC power supply , multi meter and Hot air gun if that helps . Attached the schematic as well
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Help me remove shorting Compal LA- 5752p
    What's the exact resistance to ground on +1.05VS?
    • IamPritesh
      • Aug 2017
      • 356
      • India
      Its 0.008
      • IamPritesh
        • Aug 2017
        • 356
        • India
        Tried with another CPU as well.. no luck.
        • piernov
          • Jan 2016
          • 4439
          • France
          Resistance in ohm, not diode mode.
          • IamPritesh
            • Aug 2017
            • 356
            • India
            Its 0.00 in ohms
            • aanan
              • 222
              • India
              remove cpu & check res also check q11 remove L25,L26 & check res.
              • piernov
                • Jan 2016
                • 4439
                • France
                Lots of stuff on +1.05VS, easiest is to inject 1V at 3 or 4A and check what gets hot, without CPU. First suspect: PCH.
                But first you can remove PJ14 and check that the short is on +1.05VS and not +1.05VSP.
                • IamPritesh
                  • Aug 2017
                  • 356
                  • India
                  Its 0.02 ohms at PJ1 if I remove the CPU
                  • IamPritesh
                    • Aug 2017
                    • 356
                    • India
                    PJ14 is not connected and its short only on one side ( +1.05VS )
                    • IamPritesh
                      • Aug 2017
                      • 356
                      • India
                      Removing L25 and L26 has removed the tick tick sound when CPU is attached to the socket.
                      But now board does not even start without cpu ..no leds glowing, no 3 or 5 volt on the coils
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        Sorry misread the schematics, +1.05VS is obviously taken from +1.1V_VCCPP, not +1.05VSP…
                        Try to inject 1 volt on +1.05VS still.
                        • IamPritesh
                          • Aug 2017
                          • 356
                          • India
                          The DC power supply does not show shorting after removing L25 and L26 , but there is no 5 volt or 3 Volt even without the CPU .
                          Have i messed it up ? Earlier I could atleast start the board without CPU ..
                          Please suggest
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            Check resistance on both pads of L25 and L26 to see if there is a short there.
                            • IamPritesh
                              • Aug 2017
                              • 356
                              • India
                              L25 and L26 has 0.00 ohms on side of the pad
