Help me remove shorting Compal LA- 5752p
  • IamPritesh
    • Aug 2017
    • 356
    • India
    I had this laptop which had flickering screen but everything else was working fine.
    I tried a new lvds cable and that is when things got even worse. now the laptop does not start at all.
    If I remove the cpu, then it try to start though with leds glowing , fan moving and then shutting down obviously.
    If I put the cpu back and plug in the ac adapter, i can hear a tick tick sound coming from the cpu ..
    Upon checking I can see shorting in the 1.05VS line. PJ1 has shorting on the +1.05VS side.
    I have DC power supply , multi meter and Hot air gun if that helps . Attached the schematic as well
  • piernov
    • Jan 2016
    • 4438
    • France
    Re: Help me remove shorting Compal LA- 5752p
    What's the exact resistance to ground on +1.05VS?
    • IamPritesh
      • Aug 2017
      • 356
      • India
      Its 0.008
      • IamPritesh
        • Aug 2017
        • 356
        • India
        Tried with another CPU as well.. no luck.
        • piernov
          • Jan 2016
          • 4438
          • France
          Resistance in ohm, not diode mode.
          • IamPritesh
            • Aug 2017
            • 356
            • India
            Its 0.00 in ohms
            • aanan
              • Dec 2010
              • 222
              • India
              remove cpu & check res also check q11 remove L25,L26 & check res.
              • piernov
                • Jan 2016
                • 4438
                • France
                Lots of stuff on +1.05VS, easiest is to inject 1V at 3 or 4A and check what gets hot, without CPU. First suspect: PCH.
                But first you can remove PJ14 and check that the short is on +1.05VS and not +1.05VSP.
                • IamPritesh
                  • Aug 2017
                  • 356
                  • India
                  Its 0.02 ohms at PJ1 if I remove the CPU
                  • IamPritesh
                    • Aug 2017
                    • 356
                    • India
                    PJ14 is not connected and its short only on one side ( +1.05VS )
                    • IamPritesh
                      • Aug 2017
                      • 356
                      • India
                      Removing L25 and L26 has removed the tick tick sound when CPU is attached to the socket.
                      But now board does not even start without cpu ..no leds glowing, no 3 or 5 volt on the coils
                      • piernov
                        • Jan 2016
                        • 4438
                        • France
                        Sorry misread the schematics, +1.05VS is obviously taken from +1.1V_VCCPP, not +1.05VSP…
                        Try to inject 1 volt on +1.05VS still.
                        • IamPritesh
                          • Aug 2017
                          • 356
                          • India
                          The DC power supply does not show shorting after removing L25 and L26 , but there is no 5 volt or 3 Volt even without the CPU .
                          Have i messed it up ? Earlier I could atleast start the board without CPU ..
                          Please suggest
                          • piernov
                            • Jan 2016
                            • 4438
                            • France
                            Check resistance on both pads of L25 and L26 to see if there is a short there.
                            • IamPritesh
                              • Aug 2017
                              • 356
                              • India
                              L25 and L26 has 0.00 ohms on side of the pad
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • IamPritesh
                                Lenovo NM-C121 board,Help remove shorting from burnt pad
                                by IamPritesh
                                Hello friends,
                                I keep coming back for help and this community has never disappointed me. So I have this Lenovo NM-C121 board which has no display on screen. Works fine on external display though. Found one of the fuse (F3301) is burnt that supplies the power to the screen. (20 V)
                                After cleaning the area I can the damage already done. The area between the pads is burnt. What bothers me that it still shows short on the edp connector side even though there is not a single component on this side ( LVDS cable is not connected )
                                How can remove the short...
                                09-19-2022, 12:31 PM
                              • longmt1990
                                Panasonic Cf-w5 bios password remove
                                by longmt1990
                                Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                Please help me remove bios password.
                                Thank you so much
                                07-06-2025, 10:50 PM
                              • Maxpower3
                                Hantek 365 Remove screen on startup
                                by Maxpower3
                                every time I open the tool, I have the screen that appears
                                and I am always in a hurry to use it so I click and it automatically sends me a link to the manufacturer.
                                It annoys me lol.
                                2 solutions to remove it.
                                Either you remove pic.bmp and it no longer appears so no more links when clicking.
                                hope this helps users...
                                01-15-2025, 03:24 PM
                              • samirinfo
                                Lenovo Yoga slim 7 14ITL05 Bios dump/Password remove
                                by samirinfo
                                Can I remove my bios dump?
                                SN: LR0EJB0E
                                Factory ID: CS20
                                Lenovo Yoga 7 14ITL05
                                Board: DALSBMBAG0 REV : G
                                HELP PLZ
                                post moved..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.....
                                12-28-2025, 07:48 AM
