Toshiba L50B wrong GPU temperature+IntelManagement error
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I've got one sick little laptop here today: it's a Toshiba L50B, which is a POS to begin with (broken hinges, missing covers, it's a mess), but it also displays some complex symptoms: on top of random shutdowns, speedfan reports a totally ludicrous GPU temperature of 150-something degrees and I also get a "status_device_power_failure" message in device manager undel Intel Management Interface, so I think all these might be related. Is this a failed hardware components that's causing this ? I could ignore the temperature reading if the laptop was fully functional otherwise, but it's not...
    The driver fails to install with an error message that basically says it cannot connect to something - can't quite remember how it went.
    The motherboard is a DABLIDMB8E0 Rev e if we can even get that far with the repairs Cheers and thanks for any support.
    Wattevah...
    • 21960
    Re: Toshiba L50B wrong GPU temperature+IntelManagement error
    Post your bios backup. Might be the ME are of the bios is corrupt .
    EDIT: First, uninstall the management engine drivers,reboot and install the latest driver,that might fix it,if not, post your bios backup.
    Tosh ME Driver http://files.ecp.toshiba.com/2016/08...CF0015900F.exe
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      So I'd need to remove the BIOS chip, read it and post the resulting BIN ?
      EDIT: The driver you provided did install successfully, but the error is still there in dev manager.
      Wattevah...
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        I agree with smdflea. All symptoms indicates towards me region corruption in bios.
          • 21960
          Yes,you can backup the bios that way with a programmer.If you have a sop8 clip you don`t need to desolder it.
          You can also try backing it up via software,but if the flash descriptor area of the bios is locked (probably)you won`t get a full backup only partial.Theres some software called bios backup toolkit,on these forums if you search for it, thats the easiest way or you can use intels Flash Programming Tool ,from the command line.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Naah...just bust out the clip and do it that way. I shall post my results tmmoz hopefully...I HATE taking this thing apart, all broken and smashed, falling into a million pieces.
            Did I mention it randomly shuts down ? I did Could it be related to what I'm trying to fix ?
            Wattevah...
              • 21960
              Yes,its related to the shutdown,usually at around 30 seconds.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                It's not that abrupt - in my case it takes like 30-60 *minutes* for it to die, but it DOES happen nonetheless...
                Wattevah...
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  30 minutes is ME region. If it lasts longer, that may be something else (overheating). But still, ME region is a good candidate.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Already replaced the thermal grease and dusted the fan, so it's definitely not overheating, though it could be that something else is failing when it starts getting warm. Still, it happens at idle temperatures too...I shall dig further tomorrow.
                    Wattevah...
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      Here's what came off of that BIOS chip. I actually had to remove it to read it, because with it still on the board the power LED on the programmer would go dim and the software would tell me it's not connected, so I think it's trying to power something on the board as well....anyway. I'm not sure what it's supposed to look like, but here you go. The chip showed up as "unknown" and the software wasn't able to determine what chip it actually is, so I hope it's OK.
                      EDIT: I noticed there's also a 24C08 chip on there, so I read that as well. I can see somewhere among the Hex code the model PSKTCE on there.
                      Wattevah...
                      • mielta
                        • Apr 2015
                        • 368
                        Hi
                        it is fixed Bios
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Is that a file you already had, or you edited mine ? If so, I'd like to know what you did to it.
                          I also discovered the laptop doesn't turn on with a different IC on there: not wanting to mess around with the original IC, I though I'd try a different one for testing, so I programmed a different 25Q64 with what I obtained from the original IC and the laptop just stood there with its caps lock light on and that's it......is there a difference between a 25Q64 and a 25B64 ? The B version is the original. It could be that the original bin wasn't ripped correctly in the first place, hence why it refuses to run with other ICs....
                          EDIT: same thing with the BIN you sent: on a different chip, it just stays there....I'll try it with the original, see if it changes anything. I'm a bit reluctant TBH
                          Wattevah...
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            Update: tried out the BIOS mielta sent on the original chip, it works (so the IC is important after all), but I still get two 511C readings for the GPU temperature and the error in dev manager is still there...don't know what to make of this...
                            Wattevah...
                              • 21960
                              Great, i`m glad its half fixed. And i do know its 30 *minutes* and not seconds as i said at post #7
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                No, it's not fixed, that's just it The chip programmed fine, but I'm still having the same issue Sorry...I think there's something dead on the motherboard...
                                Wattevah...
                                  • 21960
                                  heres a link to the 1k rom dump, 24C08 https://www.badcaps.net/forum/showthread.php?t=47053 post #8 or #9
                                    • 21960
                                    This might help: https://superuser.com/questions/9950...of-511-degrees
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      I don't know why people are still using Speedfan. It is horribly outdated. Try HWINFO for a change.
                                      A working TV? How boring!
                                      • jean luc ferre
                                        upgrading windows7 to windows10 on an old laptop toshiba satellite m40 331 allways in error
                                        by jean luc ferre
                                        on this old laptop toshiba satellite m40 331 i am trying (but failing) to upgrade frow w7 to w10 and allways i have the error : 0xc1900101 - 0c20017. The upgrading process stops with the pc blocked with the logo screen w10 on the display; then there is no activity on the disk hdd or ssd.
                                        it's also impossible to boot from a dvd iso bootable, the device equally blocks on the w10 logo screen...
                                        i verified the informations in the device manager and it seems there are no problems...
                                        i wonder if it's not an issue about the bios (which is very old) or an interface problem...
                                        05-27-2025, 07:13 AM
                                      • Sus256
                                        HISENSE 65E7KQ PRO - no boot
                                        by Sus256
                                        Hi all!
                                        HISENSE 65E7KQ PRO
                                        RSAG7.820.13512 - chassis
                                        MT9618BAATAB - cpu
                                        RSAG7.820.12059 - power
                                        HD650Y3U77 - panel
                                        KLM8G1GETF - emmc
                                        The TV does not turn on, the standby indicator is on. All voltages are present.
                                        Emms is dead. Not readable, not detected.
                                        Replaced emmc.
                                        But with another dump there is no launch
                                        Terminal log
                                        UART
                                        AC_ON
                                        RPMB key is not yet programmed
                                        HASH1_VERSION=0x00000000 64bit
                                        E-B
                                        FDE enabled
                                        layout pattern onebin by SAR7,0...
                                        06-01-2025, 02:11 AM
                                        09-06-2024, 05:27 AM
                                      • sushilachuthan
                                        APC UPS error P13
                                        by sushilachuthan
                                        one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                                        the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                                        The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                                        We replaced the SCR with new device,, but the device is not power on as expected.
                                        Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                                        09-26-2025, 09:00 AM
                                      • CornholioGSM
                                        RT809H - direct read Toshiba eMMC timeout error
                                        by CornholioGSM
                                        Hello all,
                                        help needed.
                                        I want to made backup of boot and all partitions from emmc desoldered from old phone.
                                        So i have wired emmc directly to RT809h - Dat0, GND,CMD, CLK, VCC, VCCQ - on programmer sw set Smart Identify to EMMC ISP and voltage to 3.3V.
                                        In Settings (N) i have set area to user, boot1,boot2 and EXT and vccq set to 1.8V (tested 3.3V too).
                                        Problem is, that i still get Read Timeout Error
                                        OK - emmc can be dead...so i have tested emmc wires connection to micro SD adapter and then in card reader and emmc was detected.
                                        So...
                                        01-16-2025, 04:34 PM
