Lenovo ideapad 310-15IKB No Power
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    hello to all BadCaps
    I have Receive for repair
    Model: Lenovo ideapad 310-15IKB
    MOBO: NM-A981 Rev:1.0 (2016-06-16)
    Unit Status: No Power
    i check. have supply on rail. then i press power button. nothing happen no indicating power even light. but i try to hold the CPU & GPU heating Up.
    I check the 3.3Valw and 5Valw have and 1.8V Have
    then i check the supply on switch why 2v only. i think it is 3v?
    anyone can help me solve this or can you give me a Schematic .
    Thanks In Advance
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Re: Lenovo ideapad 310-15IKB No Power
    Up Up Up
    • juffe
      • Aug 2020
      • Finland
      same problem here, any help?
      • khaahk
        • Dec 2013
        • 812
        • Estonia
        schematic is available:
        https://www.badcaps.net/forum/showthread.php?t=77863
        post measurements to have some information to go on...
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          Better make a new thread.
          Start by basic things : measurements ,resistance and impedance on all coils than post all that here
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            if its not turning on and all power rails are ok and all ALW voltage are present.. try to check the power switch 3.3V and 0v when on. try substituting known good memory module. place an external monitor and check. check the bios ic vcc.. rtc button battery. if ok. try to flash the bios with known good dump.. gud luck!
            Never stop LEARNING because life never stops TEACHING!
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              remove solder on JUMP_43X79 and measure voltage here.
              check also volts on pu401 pins
              could be ec need reprogramming ?
              • Dr.d
                Help please..Lenovo ideapad 5 14itl05 power and charging problem
                by Dr.d
                I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                04-05-2024, 11:48 AM
              • gleniu
                Lenovo IdeaPad Gaming 3 15ACH6 - no power
                by gleniu
                Hi, I have a problem with a Lenovo IdeaPad Gaming 3 15ACH6 laptop. My nephew asked me to replace the charging port because the laptop wasn't charging. This issue had happened in the past, so I knew that replacing the port was only a matter of time. Until now, my nephew managed to deal with the problem using a temporary solution: bending the positive metal tabs inside the port with a thin tool. However, this had stopped helping for a while. Today, I replaced the port – and to my surprise, after the replacement, nothing happens when I plug in the charger: the power LED doesn't light up, the laptop...
                Today, 01:13 PM
              • rabsonnjala
                LENOVO IDEAPAD 100 works only on bench power supply
                by rabsonnjala
                Hie I have a Lenovo laptop
                Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                below are my readings
                with the original charger only
                JBATT1
                PIN1 0.22V
                PIN2 0.22V
                PIN3 0.45V
                PIN4 0.45V
                PIN5 O.43V
                PIN6 0V
                PIN7 GND
                PIN8...
                11-20-2021, 08:32 AM
              • acata
                Lenovo Ideapad slim 3 not power on
                by acata
                Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
                And the consumer asked for reinstalling OS.
                I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
                Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
                Check the main power rail for 20v input ok
                No amper input from Power supply 0.013a
                Mosfet PQ201 20v and 26v ok.
                3.3v exist
                1,8v exist
                5v exist
                12v from baterai exist....
                09-30-2024, 09:42 PM
