Dell XPS L322x dead charging circuit
  • MARHD
    • Jul 2018
    • 47
    • South Africa
    Hi guys
    I'm looking to fix my XPS 13 L322x, the laptop still works 100% and im fairly certain the battery is ok, but the charging circuit as you can see in the images is blown. I really need a schematic, as the only one I can find is for sandy bridge, however the one I have is ivy bridge. Perhaps someone more knowledgeable would know if the charging circuits are the same or not. Or maybe if someone knows the components which are blown, I know its unlikely but yeah any help is good help
  • piernov
    • Jan 2016
    • 4436
    • France
    Re: Dell XPS L322x dead charging circuit
    Apparently schematics for Quanta D13B is not available. Use Quanta D13, this section should be similar enough.
    Pictures are very blurry but it looks like PQ16 and PQ17 are blown. Those are part of the AC adapter identification circuit, so without them you should have a warning about AC adapter not being recognized when turning on and the battery will not charge.
    Those components should not blow like that so I think 19V got sent into this circuit (center pin and charger voltage got shorted togother). Make sure the fault is cleared and you don't get 19V on the PSID of the power connector.
    • MARHD
      • Jul 2018
      • 47
      • South Africa
      I think I'm in trouble now, I ordered some MMST3904 and FDV301N chips to replace the blown ones. And before i changed them I thought I'd make sure they were correct so I took close up pictures of the blown components to read the markings and I think I've just bought the wrong stuff. Attached are the images
      • MARHD
        • Jul 2018
        • 47
        • South Africa
        Does anybody know if I can use the components I have, and if not which ones do I need. I'm not that good at reading smd markings
        • MARHD
          • Jul 2018
          • 47
          • South Africa
          Bump
            • 21040
            The 1st part is a BAV70W https://cdn.badcaps-static.com/pdfs/...d417ea34e6.pdf
            The 2nd i`m not sure,it could be a AO3409L .
            • MARHD
              • Jul 2018
              • 47
              • South Africa
              Rip so I did buy the wrong stuff. Can anyone confirm that the second component is a AO3409L
              • MARHD
                • Jul 2018
                • 47
                • South Africa
                Here is a better image of the component. As far as I can tell it says A9EA and 2X on the side (the E has an underscore)
                • MARHD
                  • Jul 2018
                  • 47
                  • South Africa
                  Anyone? I was hoping to order it today
                  • MARHD
                    • Jul 2018
                    • 47
                    • South Africa
                    Bump
                    • MARHD
                      • Jul 2018
                      • 47
                      • South Africa
                      b
                        • 21040
                        I`m 99% sure its a AO3409 .
                        • MARHD
                          • Jul 2018
                          • 47
                          • South Africa
                          Ok cool. I can`t seem to find the AO3409 locally but I did find the DMP3160L-7 as a cross reference. Do you think it will work? It seems pretty close (I have attached the datasheets)
                          • dellxps15
                            • Feb 2014
                            • 1590
                            • italy
                            full of ao3409 on ebay.... take time and wait for the right componnet
                            • master3112
                              by master3112
                              07-29-2025, 01:55 PM
                            • benwaterson
                              Main rail / charging circuit issues on Bucky/BenSolo 17859-1 board from Dell Vostro 5581
                              by benwaterson
                              Hi All
                              Been a while since I have been here, and a bit rusty.
                              I have the above laptop motherboard that was working and now the charging circuit is faulty.
                              Have 19v in fine until it hits PU4403 - not shorts I can see and thermal cam reveals nothing.
                              I have swapped out the ISL9538 and also the two mosfets (PU4403 and PU4405). Have 2.8v at the power switch, which pulls low when pressed - charging light comes on and goes straight off
                              Below are measurements (pin names are per the datasheet for the ISL95338 (couldn't find one for ISL9538,...
                              05-03-2024, 03:25 AM
                            • Robocop
                              Dell G3 3579 (LA-F611P) not charging
                              by Robocop
                              Hey guys,
                              I've seen several questions about this exact issue, but I've never found the fix, so I would appreciate if we can start over the whole debugging process again from start to finish, for my specific issue.
                              In the BIOS setup, (see pic) the AC adapter is detected with the correct power rating, the battery is stated as charging (when plugged in, of course), and the battery health is stated as "Excellent" (as expected, since this is a brand new battery purchased a couple of weeks ago). However, the battery never charges (the percentage never increases)....
                              06-25-2024, 08:15 PM
                            • 0x0null
                              Dell Latitude 5530 not properly charging
                              by 0x0null
                              This Dell Latitude 5530 will not charge when turned off. when turned on and in bios it will charge properly and the adapter wattage is shown.
                              I noticed that when in bios if the charger is unplugged the bios still reports the laptop as charging and the charging light in front of the laptop stays on
                              When charging, PL4401 has a stable voltage of 12.8V however when plugged in but not charging the voltage alternates between 4v and 12v on PL4401
                              Please help
                              12-16-2024, 11:06 AM
                            • SarcasticOP
                              Dell Latitude 3500 not charging
                              by SarcasticOP
                              Greetings,
                              I am working on a Bolt-L UMA MB 17938-1 board for a Dell Latitude 3500 and it is not charging. Plugging in the barrel jack and USB-C both results in about a .1a draw at 20v. I probed around and checked every capacitor I could find, as well as the inductors, and I got no shorts, so I checked to see if anything was happening under the thermal camera when plugged in and I see a slight bit of heat being generated by the Intersil 9538H IC, which appears to connect the battery to the charging line, but I may be wrong about that, I am not very strong on reading schematics, I mostly...
                              10-25-2024, 10:01 AM
