mulitimeter troubles
  • robertpritchard
    • 61
    if i get -23.40 in restiance mode does that mean the same as (0) short to ground
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: mulitimeter troubles
    It means either your meter is broken, or you're trying to measure resistance with the target device power on. Neither of which will give you valid results.
    • R_J
      • Jun 2012
      • 9607
      What do you get when you short the probes together? that should be near zero
      • retiredcaps
        • Apr 2010
        • 9271
        A low battery may also give incorrect readings. Some meters don't display the low battery symbol or do it too late.
        --- begin sig file ---
        --- end sig file ---
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          how old is the multimeter?
