Lenovo G580 La-7982p +VCC_GFXCORE missing
  • sopik78
    • Nov 2013
    • 519
    • Czech Republic
    Dear friends,
    I have laptop Lenovo G580 UMA La-7982p with no video on screen. Measured all voltages and found +VCC_GFXCORE missing.
    There is +19V CPU_B+ on PQ907 but no control power on gate from PU901.
    PU901 NCP6132A changed but with no change.
    Can anybody guide me what to check or what control power on PU901 hsould be present to load the PQ907?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo G580 La-7982p +VCC_GFXCORE missing
    VCC_GFXCORE comes up after BIOS starts to run. So CPU VCore and CPU reset signal have to be present. If they are, try to flash the BIOS.
    Also make sure the display is working and plugged in properly, and the LVDS cable is ok.
    • ugamazing
      820-02020 PPBUS_AON missing
      by ugamazing
      Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
      Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
      02-05-2025, 04:21 PM
    • jpreza
      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
      by jpreza
      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
      Looking at the card, it appears to be missing the following:
      1x 1.0uH inductor - orange square
      2x...
      11-01-2024, 10:54 PM
    • gurj1979
      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
      by gurj1979
      Hey guys.
      Need help with this one.
      Fan not spinning due to missing PWN Fan signal.
      Also 5 seconds from powering up it freezes, unless in BIOS.
      But as soon as Windows starts to load, it will freeze.
      CPU is COLD / Room temp when it freezes.
      I've replaced the CPU, same problem.
      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
      Replaced fan - same problem.
      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
      08-19-2024, 05:22 PM
    • salopian
      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
      by salopian
      Hello. I would need some advice please.
      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
      I have already replaced the logic board with another...
      02-27-2021, 07:30 AM
    • ein_individuum
      Missing Capacitator Intel I9-12900KF CPU
      by ein_individuum
      I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
      I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
      Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
      08-06-2025, 01:36 AM
