820-3476 MacBook Pro will not charge or run off the battery
  • Flippers McCoy
    Tinkerer
    • Mar 2018
    • 106
    Hello, everyone!
    I have an 820-3476 motherboard that works fine, except it won't charge or run off just the battery. When I have the battery plugged in and boot it up using an adapter, it can see how much of a charge the battery has, but it's condition is Replace Now and says "Power Source: Adapter" and "Battery is not Charging."
    I tested the battery with Coconut Battery and it's at 88% design capacity. I tried the battery in a known good computer and it worked fine (meaning I also have a known good board to compare with, should that be helpful). When I plug in just the battery into the bare board, PPVBAT_G3H_CHGR_R bounces all over the place between 4V and 11V, and CHGR_BGATE goes all over the place too fast for me to see a range. If I leave the battery plugged in and then plug in the adapter, PPVBAT_G3H_CHGR_R is between 12.56V and 12.59V and CHGR_BGATE is a solid 12.55V.
    I checked R7150 and it's getting continuity to it's respective pins on U7100.
    Any ideas on what I should check next?
    Thanks a bunch!
  • Flippers McCoy
    Tinkerer
    • Mar 2018
    • 106
    Re: 820-3476 MacBook Pro will not charge or run off the battery
    Update: Turns out if I leave the battery plugged in for a while, PPVBAT_G3H_CHGR_R ends up staying at a solid 11.57V, and CHGR_BGATE stays at 4.79V
    • Flippers McCoy
      Tinkerer
      • Mar 2018
      • 106
      No pins on U7100 are shorted to ground, either
        • 21916
        Have you checked Q7155
        • Flippers McCoy
          Tinkerer
          • Mar 2018
          • 106
          Q7155 looks pristine and seems to let power through properly, I don't think anything is wrong with it
          • BlueMidnight
            • Jan 2015
            • 489
            The thing that strikes me is that PPVBAT_G3H_CHGR_R bounces around as low as 4V. But because of the body diode in Q7155, PPVBAT_G3H_CHGR_R should never be more than a diode drop lower than battery voltage. Even if Q7155 were completely turned off.
            The only time you mentioned seeing Q7155 working was when you let it sit there a while (the gate voltage must go low to turn it on). So it's not completely above suspicion yet. But, the type of failure that could explain what you're seeing is a bit too bizarre to put near the top of my list (it acting like it doesn't even have a body diode, but then miraculously being able to turn on after sitting there).
            But, what about the battery voltage itself (PPVBAT_G3H_CONN)? Is that just as unstable?
            Perhaps something related to the SMBus or commands sent/received over same is wonky. Or the battery doesn't see the 0V SYS_DETECT_L signal that lets it know it's plugged into a board and it's okay for it to go ahead and output voltage. Or there could be an issue with the traces or battery connector itself. Etc, etc.
            • Flippers McCoy
              Tinkerer
              • Mar 2018
              • 106
              So I went back to test PPVBAT_G3H_CONN and it's stopped fluctuating like crazy the moment I plug it in and gets a solid 11.57V. When I plug in the adapter at this point the voltage on PPVBAT_G3H_CONN, PPVBAT_G3H_CHGR_R, and PPBUS_G3H slowly rise from 11.57V to 12.37V and stay there as the fan spun.
              To make sure it wasn't a fluke I disconnected everything from the board and made sure the power drained and then hooked it back up, still not doing the fluctuating thing anymore >.>
              I put it back together enough to test it in the OS, and it works fine now. I guess getting a good nights sleep was all it needed?
              One thing that I forgot to mention but may be related is that R7185 and C7185 had a small amount of corrosion on them when I first took the computer apart, but after cleaning it looked great and tested fine.
              Thanks for the help everyone, I appreciate it
              Edit: If anyone has any insights on how R7185 and C7185 might cause these symptoms, I'd love to hear it!
              • StephE
                • Mar 2019
                • 10
                i have a board showing the same symptoms here.
                Did you ever find the faulty part(s) ?
                • Flippers McCoy
                  Tinkerer
                  • Mar 2018
                  • 106
                  This was a while ago so I'm a little hazy as to the details, but as far as I can remember the computer just started magically working again after being left in the shop overnight. You win some and you lose some I guess!
                  • techfreak9356
                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                    by techfreak9356
                    09-14-2023, 11:10 PM
                  • razenxd
                    How can I charge that battery pack?
                    by razenxd
                    it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                    At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                    Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                    Now, I have noticed a few things.
                    The "dead" battery, while connected to charger and NOT Charging will...
                    12-05-2024, 06:11 AM
                  • ruletero
                    Acer a515-43 low battery charge voltage
                    by ruletero
                    Hi
                    Acer A515-43
                    LA-H801P
                    Fail: Does not charge battery, has low voltaje on connector.
                    Laptop didn't want to turn on, only charge led blinked.
                    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                    10-24-2022, 02:31 PM
                  • ACS-Repair
                    MacBook Air 2014 battery will not charge
                    by ACS-Repair
                    Hello All,
                    I have a unusual problem with a MacBook Air 2014 820-3437 that it will not charge the battery. I have 2 batteries that charge just fine in another 820-3437 so i assume that the batteries themselves are OK. One was new in 2020.
                    This board started off as a PP3v3_S5 short that was resolved (shorted capacitor) and came to life fine. While testing the computer I noticed that the battery was not charging so I checked the following components:
                    Current sensing:
                    R7121 10 ohm
                    R7122 10 ohm
                    R7151 2.2 ohm
                    R7152 0 ohm
                    06-15-2023, 11:15 AM
                  • Juan Carlos Medina Franca
                    Macbook air m1 does not charge the battery
                    by Juan Carlos Medina Franca
                    Hello, I have a MacBook Air M1 that got water on it and now the computer does not charge the battery. The USB C port does work since I can connect the computer to HDMI for example. The battery also works well since if I connect a motherboard from another MacBook Air M1, the battery charges.
                    Anyone know what can it be?​
                    06-18-2024, 11:28 AM
