ASUS UX303LN don't start with battery only
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    ASUS UX303LN
    I change ram voltage chip PU8400 because
    there was a short on EC_GPE0 -> SUSB_EC#
    I change EC also and reprogramm bios. After that (I don't know if
    this problem existed even before the repair)
    motherboard start only with
    connected adapter and charge battery , if I remove it after power on
    the system remain on.
    Only with battery the system don't start;
    on PU8100 (this chip provide voltage to charge battery and
    +3V and 5V always voltage)
    there are those voltage on this chip with battery only
    pin 3 -> VREG3 -> 3.3V
    9 -> VBST2 -> 2.5V
    12 -> VIN -> 12.5V
    19 -> VBST1 -> 2.5V
    the EC is not powered because the PS_ON signal is 0V
    It's possible there is a bios issue ?
    thanks
    • 21899
    Re: ASUS UX303LN don't start with battery only
    Can you upload the boardview .
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      motherboard ver 2
      • Francisco.s
        • 686
        • Spain
        Voltage at pin 4&5 of J6004?
        PR6001 and PR6002 are OK?
        PD6001 is also good?
        There are pulses in SMB0_DAT_CLK_CON and SMB0_DAT_BAT_CON?
        • newfoxinformatica
          • Mar 2015
          • 29
          • brasil
          Sir SMDFlea send me Bios Main and Ec please working
            • 21899
            Have a look at PU9100 . 3VA , 3VA_ECO
              • 21899
              I don`t have it.
                • 21899
                "on PU8100 (this chip provide voltage to charge battery and
                +3V and 5V always voltage)"
                Check PU8800 it provides voltage to charge the battery,and power management.
                https://cdn.badcaps-static.com/pdfs/...efe8ea3bff.pdf (read the pin description, pin 11)
                I read on notebook1 and ******* about the same problem as you`re having, in some cases only a new battery fixed it.
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  ESD protection diode is ok
                  res 6001 and 6002 ok
                  DC ONLY AC+batt
                  pin 5 -> SMB0_DAT_BAT_CON -> 0v -> 3.3 V
                  pin 4 -> SMB0_DAT_CLK_CON -> 0v -> 3.3 V
                  It's strange in the model with non removable main battery but after I change the rtc batt (totally down) the system start with battery only:
                  DC ONLY AC+batt
                  pin 5 -> SMB0_DAT_BAT_CON -> 3.3v -> 3.3 V
                  pin 4 -> SMB0_DAT_CLK_CON -> 3.3v -> 3.3 V
                  regarding the request of the bios, I attach a definitely working dump.
                  The ec does not require to be programmed.
                    • 21899
                    The RTC battery goes to DSWODVREN ,its for PCH deep sleep.
                    • brew99
                      • Jan 2019
                      • 132
                      @SMDFlea, what is is the significance of DSWODVREN signal? I have this same board with a dead RTC batt that I'm troubleshooting now. Should the board be able to boot without the RTC battery when using AC adapter?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        DSWODVREN signal=Deep Sleep Well Internal Voltage Regulator Enable: This signal enables the internal Deep Sleep 1.1 V regulators.
                        As far as your 2nd question-yes it will work without rtc battery installed.
                        • mehmet0674
                          • Mar 2015
                          • 5
                          • turkey
                          thanks
                          • mkdj
                            ASUS X571 no power : battery issue?
                            by mkdj
                            Mark and model: ASUS X571
                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                            Tests already made:
                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                            - I have removed...
                            07-14-2025, 09:16 AM
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • dhenion
                            Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                            by dhenion
                            I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                            The original board was:
                            ASUS X510UNR REV 3.0 A
                            The replacement board is:
                            ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                            It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                            01-30-2024, 01:45 PM
                          • rob777
                            Asus TUF won’t run off battery
                            by rob777
                            I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                            I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                            Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                            Thanks....
                            05-27-2025, 07:07 PM
                          • Iherduleikgemz
                            Asus FX505DY - Battery not charging - BQ24780S
                            by Iherduleikgemz
                            Hello everyone
                            I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                            I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                            01-13-2025, 03:54 PM
