HP 9470m Change MAC ADRESS
  • szupak
    • Aug 2016
    • 7
    • Poland
    Hi!
    I've programmed 5 pieces of this model from this forum dump and I have an address conflict on the network. The problem is that laptops (dump) have the same MAC address. I tried to replace it by editing the dump, but after such a procedure the LAN card is completely not detectable. Please help me with which tool can I change the MAC address?
    Thank you for every clue
    • 20309
    Re: HP 9470m Change MAC ADRESS
    You need NbDmiFit .Start with the newest ,then if that doesn`t work go backwards, 2.11,2.10 etc . Look here:
    https://www.badcaps.net/forum/showth...light=nbdmifit
    • szupak
      • Aug 2016
      • 7
      • Poland
      Thanks for your replay. I try NbDmiFit but it allows to change serial numbers- not MAC adress
        • 20309
        Try version 2.02
        • gk89
          • Nov 2016
          • Greece
          i had the same problem with 200 9470m, i sended them back to the seller.
          try bios programming and dmi.
          you have to remove the eeprom, program it with a new "blank" bios with uuid fffffffffffffff, solder back and use dmi to fix.
          because you have 5 it may be cost effective to do it, but in my case with 200 laptops and wasn't worth it...!!! good luck.
          • saidbe
            • May 2017
            • 42
            • Chilo
            anyone who try other methode?
            When the laptop wants to add to new domain (from Azure ), it says the laptop is connected to another domain. Apparently the mac adress is the problem
            • harshana
              • Aug 2022
              • 207
              • Sri Lanka
              I have probook 430 g4 and it allow me to change mac from bios menu. haven't you try from bios?
              • saidbe
                • May 2017
                • 42
                • Chilo
                thanks, but with 9470m is not possible.
                • mon2
                  • Dec 2019
                  • 13830
                  https://www.groovypost.com/howto/cha...indows-10-why/
                  • harshana
                    • Aug 2022
                    • 207
                    • Sri Lanka
                    Then you should flash bios again.
                    • saidbe
                      • May 2017
                      • 42
                      • Chilo
                      Thanks, but why i read in #5, with a new "blank" bios with uuid fffffffffffffff
                      Is een bin from badcaps not working.
                      For HP i am using Unlocker
                        • 20309
                        Clean the ME firmware
                        • mon2
                          • Dec 2019
                          • 13830
                          Why can you not change the MAC ADDRESS with the utility linked earlier ?
                          We have done this with success for mac address locked CAD tools so that we can develop at the office or home office.
                          • saidbe
                            • May 2017
                            • 42
                            • Chilo
                            thanks for your answers..
                            i remove bios password for +20pieces of 9740m with Unlocker. Without any problem.
                            The buyer of this laptops could not add to new domain cause mac adress..
                            Next time i clean ME firmware and i see what happend.
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • Mephysis
                              DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                              by Mephysis
                              Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                              I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                              03-27-2025, 02:34 AM
                            • Andreas_de
                              Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                              by Andreas_de
                              Hello!
                              i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                              Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                              Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                              04-12-2025, 10:38 AM
                            • re-atari
                              Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                              by re-atari
                              Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                              Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                              02-03-2025, 06:49 PM
                            • Buzzfuzz2k
                              Bios password removal on a Unowhy dump
                              by Buzzfuzz2k
                              Hi Everyone,
                              I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                              The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                              the Computer is a Unowhy small pc
                              N° UYM6524702229
                              After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                              My first attempt was to get the bios dump from windows...
                              11-13-2023, 07:37 AM
