HP 9470m Change MAC ADRESS
  • szupak
    • Aug 2016
    • 7
    • Poland
    Hi!
    I've programmed 5 pieces of this model from this forum dump and I have an address conflict on the network. The problem is that laptops (dump) have the same MAC address. I tried to replace it by editing the dump, but after such a procedure the LAN card is completely not detectable. Please help me with which tool can I change the MAC address?
    Thank you for every clue
    • 21984
    Re: HP 9470m Change MAC ADRESS
    You need NbDmiFit .Start with the newest ,then if that doesn`t work go backwards, 2.11,2.10 etc . Look here:
    https://www.badcaps.net/forum/showth...light=nbdmifit
    • szupak
      • Aug 2016
      • 7
      • Poland
      Thanks for your replay. I try NbDmiFit but it allows to change serial numbers- not MAC adress
        • 21984
        Try version 2.02
        • gk89
          • Nov 2016
          • Greece
          i had the same problem with 200 9470m, i sended them back to the seller.
          try bios programming and dmi.
          you have to remove the eeprom, program it with a new "blank" bios with uuid fffffffffffffff, solder back and use dmi to fix.
          because you have 5 it may be cost effective to do it, but in my case with 200 laptops and wasn't worth it...!!! good luck.
          • saidbe
            • May 2017
            • 42
            • Chilo
            anyone who try other methode?
            When the laptop wants to add to new domain (from Azure ), it says the laptop is connected to another domain. Apparently the mac adress is the problem
            • harshana
              • Aug 2022
              • 216
              • Sri Lanka
              I have probook 430 g4 and it allow me to change mac from bios menu. haven't you try from bios?
              • saidbe
                • May 2017
                • 42
                • Chilo
                thanks, but with 9470m is not possible.
                • mon2
                  • 14681
                  https://www.groovypost.com/howto/cha...indows-10-why/
                  • harshana
                    • Aug 2022
                    • 216
                    • Sri Lanka
                    Then you should flash bios again.
                    • saidbe
                      • May 2017
                      • 42
                      • Chilo
                      Thanks, but why i read in #5, with a new "blank" bios with uuid fffffffffffffff
                      Is een bin from badcaps not working.
                      For HP i am using Unlocker
                        • 21984
                        Clean the ME firmware
                        • mon2
                          • 14681
                          Why can you not change the MAC ADDRESS with the utility linked earlier ?
                          We have done this with success for mac address locked CAD tools so that we can develop at the office or home office.
                          • saidbe
                            • May 2017
                            • 42
                            • Chilo
                            thanks for your answers..
                            i remove bios password for +20pieces of 9740m with Unlocker. Without any problem.
                            The buyer of this laptops could not add to new domain cause mac adress..
                            Next time i clean ME firmware and i see what happend.
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
                            • mkdj
                              by mkdj
                              Dear all,
                              10-19-2025, 04:41 AM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • Mephysis
                              DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                              by Mephysis
                              Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                              I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                              03-27-2025, 02:34 AM
                            • dell_bios
                              Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                              by dell_bios
                              I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                              The board has three SPI flash chips:
                              - W25Q64FV (main BIOS)
                              - W25Q32FV (EC/TPM)
                              - W25X10CL (configuration)
                              I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                              The dump contains protection that needs to be removed.
                              If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                              I’m also happy to share my dump for comparison if needed.
                              Laptop model: [please specify, e.g....
                              10-16-2025, 04:28 PM
